Horizontal window?
Started by 325ABN, January 19, 2011, 10:34:44 PM
325ABN
If I installed a normal double hung window on the horizontal plane would it work ok? ??? ???
  A vinyl double hung , or a wood window?
Either way if it's a modern window no it wouldn't work very well. If it's a old wood double hung it would work very well either.
They have springs or weight that assist with the lifting , and that hold the window open , those springs are designed to use the weight of the window in that process, laying the window sideways would muck up the action.
325ABN
Not sure about the vinyll or wood as I have not purchased the window yet.
Alan Gage
Thought about trying that a few years ago but found if you turned a new double hung window on it's side it wouldn't stay closed.
Alan
Quote from: 325ABN on January 20, 2011, 07:45:04 AM
That makes the right answer pretty simple , buy a slider. A window made to be used the way you intend.
A true horizontal slider, like the ones I've used, has rollers on the lower edge to make it glide back and forth. That would be missing on the window meant for vertical use.
The drains would also be missing, or rather they would be on the left or right side where they would do no good. Maybe do bad?
poppy
Just to reinforce what others said; I bought a bunch of vinyl double hung windows for cheap and I had the same question.
When I laid one on it's side and released the locks, it literaly flew open.  Not a good idea.
