Built up beam fastener
Started by astidham, June 15, 2010, 12:06:57 PM
astidham
The built up beam html calls for a 4.5 to 5 inch nail. Where do you find a 5" nail, Lowes no success  ???
— Henry Ford
FrankInWI
The purpose of the longer nail is to tack all the layers together. They are not structurally functional as it is the wood doing the work.
When I built my cabin foundation beams I used 3 1/4 inch air nailer nails. I built it up one layer at a time, nailing the third and fourth layers to the center two. Mine were 4 layers of 2x, no spacing materials.
astidham
Thank You MountainDon i will do the same
— Henry Ford
kev_alaska
Same here as MountainDon did. My pole barn beams were three 2X10s with 1/2" plywood sandwitched for fill. 52' long.
kevin
Stealing ideas from John, PEG and Glenn for a several years now.......
