Homeowners ASSociations Suck!
Started by tjm73, October 29, 2007, 09:42:13 PM
tjm73
#25
QuoteThat antenna is probably overkill. I have a slightly smaller, shorter with fewer elements, antenna and I'm about 10X farther away from the broadcast towers. Although having tress in the way may degrade the signal a little.  :-/  If you can get it into the attic and unfold it it should be fine. Be certain to ground the coax cable using a coax grounding block.
Did you try the Solid Signal website for a recommendation on the antenna?
http://www.solidsignal.com/antenna_selector.asp
Overkill in my middle name. :D Can't hurt reception and I'm willing to pay the $60 bucks.
I have not done the solidsignal thing but will. Thanks.
An antenna amplifier can really improve the signal also if that hasn't been mentioned -- and while you are at it why not put and electric in attic antenna rotator also. :)
firefox
Just a note. Trees do suck up a lot of signal. A lot more than you would think.
But it does depend on the frequency and I am not that knowledgeable about
TV. We were testing the propogation of our wireless network devices and it turned
out that the trees interfeared more than some of the building walls.
YMMV
Bruce
Bruce & Robbie
MVPA 23824
