Roof Insulation - Outside
Started by FrankInWI, October 02, 2007, 09:59:13 AM
FrankInWI
 :(On the dormers I'm building, I can't loose much more head room, so I'm stuck with 6" insulation (cause of the air vent and demensional size of the 2 X 8 rafters) unless I go outside the roof.
:-?Can I put insulation sheeting between the rafters and plywood sheeting?
::)Other solution?
god helps those who help them selves
You could use larger rafters, 2x10's etc.
Using a spray in like Icynene which has higher R-value per inch than fiberglass. Probably more pricey than going to oversize rafters.
FrankInWIS
rafters become the ceiling on the dormers, and it's getting lower already as it comes to the outside wall.  Just hate to take more headroom (I'm 6' 4" and my boys are getting there) for more insulation.  Thought maybe I could just put a some 4 x 8 sheet insulation under the plywood roof sheating.
