I have a question
Started by Gras1990, May 11, 2024, 03:58:14 AM
Gras1990
I am looking into building the 1 and 1/2 story wondering what the cost has been for some of you , less the land , trying to put a plan in order any help thank you.
rothbard
I am framing the 1 story right now which is based on the same footprint.
It was about 4500 to do my crawlspace foundation (6" CMU 4 high, fully grouted, plus footing, excavated to 12").  Including renting a backhoe.
The framing I'm looking at about $15k all in, plus another 12-15k or so for roofing/sheathing/windows.  I think maybe you have similar subfloor unless you do a slab.  I spent about $4k on my subfloor including select structural floor joists for the called out 2x12x20'.
I anticipate finishing the shell for under 40k including the plumbing from the house to the septic system.  Utilities cost me another ~35k including a septic system, power extension 1/5 mile, DIY power run 300 ft from property line, temp power for construction, running water and temp spigot a few hundred feet to the property line.
Bruce Gardner
Thanks @rothbard for sharing the details. I am also looking into this. Can you share more?
rothbard
Quote from: Bruce Gardner on December 25, 2024, 04:15:08 AMThanks @rothbard for sharing the details. I am also looking into this. Can you share more?
Sure.  I have the whole house almost framed now except overhanging parts of roof.
 I have a spreedsheet of costs, what parts were you interested in?
