Medeek Project Plugin
Started by Medeek, January 14, 2023, 04:50:14 PM
Medeek Engineering
Interior Bearing (ie. footing + post & beam) are now added to the House Builder.
Nathaniel P. Wilkerson
Medeek Engineering
I've also enabled the entry stair option for foundation door openings.
Medeek Engineering
I'm also adding gable walls as well as shed and hip.
Medeek Engineering
Currently the various plan view tabs are treated as their own "sheets" or pages. In other words if you print that tab you get exactly what is in the viewport scaled to fit into a regular sheet size (letter, 11x17, Arch C, Arch D). You cannot add in other geometry from other tabs. This seems to work reasonably well for most of these plan views (ie. Floor Plan, Foundation Plan, Roof Plan, Floor Framing Plan etc...)
However, when it comes to elevation views things typically get a bit more interesting. Some designers like to put multiple elevation views on one sheet and in some cases all four if they will fit ( I like to do this for small ADUs for example). So it is not as easy as assigning one elevation view to one sheet, or even assigning two elevation views to one sheet, there needs to be more flexibility.
After giving this some considerable thought I decided what I really needed was a Layout system where the user can drag the elevations into the "workspace" and position them as they see fit, and then at that point add their annotations and dimensions. I have now created four additional Layout tabs where the user can do exactly that.
The only major thing I feel like I am missing at this point is a sectional view or section tool.
Medeek Engineering
I've also add Common Truss Roofs along with Complex Roofs.
Medeek Engineering
**Version 1.2.8** - 10.11.2026
- Added the "Draw House" tool to the Medeek Builder toolbar.
I'm releasing this update so that interested parties can test out the House Builder interface.  It is currently not fully wired into the Medeek API so have temporarily disabled the "Create House" button.  I will be spending the next week or two completely the upgrades to the Medeek API for the various mdkBIM extensions so that we can access API methods for floors, foundations, roofs etc...
The primary purpose of this update is to garner feedback on the UI and the front end.  Please download and install this latest update and send any feedback directly to nathan@medeek.com.  I will be very curious what everyone thinks of this new tool and I think you will find it is much more capable than the "prototype" Garage Builder".
Medeek Engineering
Version 1.3.0 - 10.19.2026
Wired up the Medeek API with the House Builder so that assemblies can be created with the following extensions: Wall, Truss, Foundation and Floor.
Note that in order for the House Builder to work correctly you will need to upgrade your Wall, Truss, Foundation and Floor extensions to the latest versions (also released on 10.19.2026).
Medeek Engineering
**Tutorial 8** - House Builder (19.42 min.)
Medeek Engineering
The House Builder is now building all wall-hosted electrical fixtures:
Medeek Engineering
Tutorial 9 - Electrical Plans (14.41 min.)
Unfortunately I forgot to show the electrical legend in this tutorial.
Medeek Engineering
First look at the Block Editor and Block Library Manager.
Medeek Engineering
