Building walls in segments
Started by retiredmarine, June 19, 2019, 11:34:07 AM
retiredmarine
Ok the subfloor is finished.
Tomorrow (rain today) I start laying out walls. The 2 through walls are 40' each, a bit much for me to raise by myself. Any issues or special considerations in building them in say 12' segments? I'll sheath them after they are standing.
Adam Roby
Looks good... don't forget your dance!  It's kind of a tradition around here...
ChugiakTinkerer
The top plate obviously goes on after.  it's best if you can lay out the walls so that sheathing seams don't land on a wall joint.  Don P made a suggestion on my build thread to only partially frame in your windows and doors, then finish framing them in once standing.  Also, a set of wall jacks can often be picked up on Craigslist for cheap.
retiredmarine
Partially framing seems like adding steps.  Why would you do that? What's the need to partially frame? The sheathing will bridge the wall segments thereby strengthening the joint. And the top plate would tie each wall segment along the long walls together.
I think by "partial framing" he means to leave out the heavy parts like headers and maybe jack studs until after the wall is raised into place. ,... less weight to lift
ChugiakTinkerer
Quote from: MountainDon on June 19, 2019, 02:55:17 PM
Exactly right, the issue was raising a heavy wall.
https://countryplans.com/smf/index.php?topic=14680.msg191761#msg191761
retiredmarine
Oh, got it! Yup, it's all about saving the back at my age! LOL
azgreg
When I read the thread title I thought of this project. Panelized construction.
https://countryplans.com/cody.html
retiredmarine
Interesting! Almost like they were made in a workshop and then driven to the site for install!
azgreg
Quote from: retiredmarine on June 19, 2019, 08:41:24 PM
Here's another thread on the project.
https://countryplans.com/smf/index.php?topic=2178
Curious to see how it turned out and how it's held up.
