Electronic Voting Machines
Started by Sassy, November 28, 2007, 12:54:18 PM
Great video on an investigation by a gov't panel on the electronic voting machines - must see!
http://www.youtube.com/watch?v=JEzY2tnwExs
Wow... very interesting.  The founding fathers would roll over in their graves.
StinkerBell
I think they have been rolling for years.....
  http://www.bradblog.com/
Ohio Voting Machines Contained Programming Error That Dropped Votes
By Mary Pat Flaherty
A voting system used in 34 states contains a critical programming error that can cause votes to be dropped while being electronically transferred from memory cards to a central tallying point, the manufacturer acknowledges.
The problem was identified after complaints from Ohio elections officials following the March primary there, but the logic error that is the root of the problem has been part of the software for 10 years, said Chris Riggall, a spokesman for Premier Election Solutions, formerly known as Diebold.
The flawed software is on both touch screen and optical scan voting machines made by Premier and the problem with vote counts is most likely to affect larger jurisdictions that feed many memory cards to a central counting database rapidly.
Riggall said he was "confident" that elections officials through the years would have realized votes had been dropped when they crosschecked their tallies to certify final elections results and would have reloaded cards so as not to lose votes. Ohio Secretary of State Jennifer Brunner has said no Ohio votes were lost because the nine Ohio counties that found the problem caught it before primary results were finalized.
As recently as May, Premier said the problem was not of its making but stemmed from anti-virus software that Ohio had installed on its machines. It also briefly said the mistakes could have come from human mistakes. Further testing by Ohio elections officials and then high volume tests by Premier uncovered the programming error.
"We are indeed distressed that our previous analysis of this issue was in error," Premier President Dave Byrd wrote Tuesday in a letter that was hand-delivered to Brunner. Premier and Brunner are in an ongoing court battle over the voting machines and whether Premier violated its contract with the state and warranties. Half of the Ohio's 88 counties use the GEMS system. Brunner has been a vocal critic of electronic voting machines,
Both Brunner and Premier said that remedies to the problem will be in place for the November presidential election. A nationwide customer alert with recommended actions was issued Tuesday by Premier. Approximately 1,750 jurisdictions use the flawed system, Riggall said. Both Maryland and Virginia use it, he said, although Virginia does not relay its votes to a central counting point, which is where the problem surfaces, Riggall said. Maryland does use a central count, he said. The District of Columbia does not use the GEMS system.
The problem is most likely to affect larger jurisdictions that upload multiple memory cards during counts, Riggall said. The GEMS system is supposed to save information from one card at a time to be counted in order as the cards are read by a database that Riggall described as the "mother ship." But a logic error in the program can cause incoming votes to essentially shove aside other votes that are waiting in the electronic line before they are counted. The mistake occurs in milliseconds, Premier's customer notice says.
The mistake is not immediately apparent, Riggall said, and would have to be caught when elections officials went to match how many memory cards they fed into a central database against how many show as being read by that database. Each card carries a unique marker.
http://voices.washingtonpost.com/the-trail/2008/08/21/ohio_voting_machines_contained.html
