PT (pressure treated) wood foundation
Started by John Raabe, March 18, 2006, 11:33:31 AM
A fellow named Danny Kay tried to post this to the old forum. It is a good set of links.
PWF stands for Permanent Wood Foundation and it is also called a PT wood foundation.
The Permanent Wood Foundation is a very viable foundation for areas where concrete is difficult to deliver or for owner-builders who want to use standard framing techniques with only a few new details to learn. Such foundations are particularity good for a basement that will be finished out. The finished space is larger, and more comfortable than would be the case in a concrete basement. Such a framing system is also good for earth sheltered designs.
Kay suggests having a third party inspection. He found information and links to inspectors at these web sites. http://www.southernpine.com and http://www.cwc.ca.
The Southern Pine Council has free and low cost publications on PWF. This is some of the best information available and anyone planning to build using this system should get a copy of the free "Design and Construction Guide".
http://www.pwfs.com/index123456789.html - has slide shows of PWF installations and more information.
Note: in some areas of the country foundation grade wood is made from wood species other than southern pine. The construction details are the same, however.
Thanks for updating that. :D It is still an option to consider for some projects.
