General => General Forum => Topic started by: Amanda_931 on March 16, 2006, 10:03:25 PM
Title: Re: Making frame walls rigid
Post by: Amanda_931 on March 16, 2006, 10:03:25 PM
I've noticed that a lot of the all-glass super-engineered, architect designed places with glass to all possible corners have (probably oversized for looks) steel cables with turnbuckles to hold them square.  Usually crossed.
I think they're ugly.  Mind you thin ones wouldn't look any better.
(and we had a small earthquake about 20 miles away last week)
Post by: jb52761 on March 17, 2006, 04:15:39 AM
I would be willing to try the steel/metal banding idea, as far as wind damage. Sounds like a reasonable idea. Probably do a little dumpster-diving at some building sites too if I could get it free.
Post by: glenn kangiser on March 17, 2006, 06:25:37 AM
There are always these when you want to spend money.  Note they replace Code 1x4 let in brace - not shear wall requirements.
http://www.strongtie.com/products/connectors/WB-WBC-TWB-CWB-RCWB.html
(https://countryplans.com/smf/proxy.php?request=http%3A%2F%2Fwww.strongtie.com%2Fgraphics%2Fproducts%2Flarge%2FWB-WBC-TWB-CWB-RCWB7.gif&hash=53e4df6df77ae3803519c78744301ad6)
See Simpson page for various styles.
Post by: glenn kangiser on March 17, 2006, 09:13:45 AM
More bracing and code info from Simpson.
http://www.strongtie.com/news/industry/wall-bracing/conventional.html
Post by: John Raabe on August 24, 2009, 01:35:23 PM
Here is a diagram of comparative wall rigidity.
(https://countryplans.com/smf/proxy.php?request=http%3A%2F%2Fwww.countryplans.com%2Fimages%2Fwall_rigidity.gif&hash=e2add6d1e83a738efec7dbc315faa50a)
Post by: Don_P on August 24, 2009, 04:49:21 PM
This link has another good description and graphic (warning, tripod sites do have an ad popup you need to close)
http://mgacon0.tripod.com/plywood.htm
Files included: 31 - 896KB. (show)
Cache hits: 8: 0.00179s for 35,098 bytes (show)
Queries used: 16.
