Internet Finds for Designer/Builders => Referral Links => Topic started by: John Raabe on December 30, 2009, 11:51:12 AM
Title: Venting wood siding to avoid paint and mold problems
Post by: John Raabe on December 30, 2009, 11:51:12 AM
I have recently added a public article on this topic at our sister site PlanHelp.com. Click the image below.
(https://countryplans.com/smf/proxy.php?request=http%3A%2F%2Fwww.planhelp.com%2Fpublic%2Fimages%2F105a.jpg&hash=021139354ae5408476602d7fb09678f2) (http://www.planhelp.com/public/105.cfm)
Title: Re: Venting wood siding to avoid paint and mold problems
Post by: RainDog on December 30, 2009, 02:36:22 PM
 I take it that this wouldn't be so beneficial if siding with Hardie products, then? I'd kinda planned on doing a rainscreen thing with 'em, but if it's not worthwhile...
Post by: ScottA on December 30, 2009, 03:14:29 PM
Actualy hardi products tend to soak up moisture so a rainscreen is the best way to go.
Post by: MountainDon on December 30, 2009, 04:19:58 PM
From what I've seen with hardie plank and sheet siding is that they only soak up the moisture when left with an edge sitting in water. The original test samples that I nailed in place have weathered rain and snow quite well, no discernible swelling, splitting or flaking. Of course it was painted on the outside. The materials I left, on purpose, with one edge on the ground were exposed to snow and water. They were not painted, other than the factory prime, so may not be a completely valid test. However, the lower inch to two inches did swell and would separate like a delamination.
Post by: John Raabe on December 31, 2009, 10:25:51 AM
Probably cheap insurance at any rate.  :D ;)
According to the report this is more likely to happen on the North and East sides of the house (less sun) and is not a problem when sidings can dry out regularly over the winter or wet season.
Files included: 31 - 896KB. (show)
Cache hits: 8: 0.00134s for 35,094 bytes (show)
Queries used: 16.
