General => General Forum => Topic started by: stricsm on May 21, 2009, 06:43:17 AM
Title: Round Post to Joist Connection
Post by: stricsm on May 21, 2009, 06:43:17 AM
I'm adding several 4" round PT posts to our pier (dock) at our cabin and need to tie them in to the existing joists (2" X 6").  I'm adding them where the decking has been removed for access.  In the past, I've thru bolted them using galvanized hardware.  Does any one know if a Simpson Strongtie connector or similar exists to make this connection easier for me to make?  I've looked around but haven't been able to locate anything suitable.
Thanks in advance,
Mark
Title: Re: Round Post to Joist Connection
Post by: MountainDon on May 21, 2009, 10:17:18 AM
I not noticed any Simpson products designed for round posts.
Their catalog is available online...
http://www.strongtie.com/products/alpha_list.html?source=topnav (http://www.strongtie.com/products/alpha_list.html?source=topnav)
Post by: Don_P on May 21, 2009, 09:52:10 PM
You're probably getting out of Simpsons products and into Cleveland Steel, more timber type stuff. A spike grid would probably do it.
Post by: lonelytree on May 22, 2009, 12:53:24 AM
Cut a flat spot where the connection is and use a Simpson product.
Post by: MikeT on May 22, 2009, 12:30:23 PM
I have found the T connectors to be quite versatile and in many ways more preferable than some of the saddle type connectors.  Heavier gauge metal.
mt
