Off Topic => Off Topic - Ideas, humor, inspiration => Topic started by: MountainDon on May 20, 2009, 05:30:15 PM
Title: My New (used, new to me) 50 cal. Rifle Arrived
Post by: MountainDon on May 20, 2009, 05:30:15 PM
Biggest caliber gun I've ever owned.  :D The wood is showing a few scuffs but the bore is great. I figure I may refinish the wood; they made loads of these, not exactly a collectors item I'd ruin by refinishing.
(https://i133.photobucket.com/albums/q75/djmillerbucket/oddnends3/mini-TC01.jpg)
It's a Thompson / Center 50 cal black powder percussion cap muzzleloader. It's a cousin to their Hawken model which has more fancy furniture (the metal parts). The Hawkens usually have brass. This has case hardened iron/steel. This is the less expensive Renegade model. The Renegade's stock isn't as fancy as the Hawken either.
(https://i133.photobucket.com/albums/q75/djmillerbucket/oddnends3/mini-TC02.jpg)
(https://i133.photobucket.com/albums/q75/djmillerbucket/oddnends3/mini-TC03.jpg)
Anyhow it's a good place to get my muzzleloading feet wet. I picked up some powder, caps, balls and bullets and other necessities at a local shop.
Hopefully we'll try it out Saturday at the range.
Title: Re: My New (used, new to me) 50 cal. Rifle Arrived
Post by: NM_Shooter on May 20, 2009, 07:45:24 PM
Hey!  I had one of those when I was 20.  I loved that gun, but it was a pain to clean.  Wash it out asap, and use breech plug grease when you reassemble.
Mine was very accurate with patched round balls, but I never could get it to shoot the maxi-balls.  It would be fun to try sabots with that gun.  I suspect the twist rate is too slow for longer projectiles though, so expect your best accuracy with balls.
I used to hunt squirrels with mine.  I would load it with 20grns of 3f behind a round ball.
PM me with info on when you are heading to the range if you want company.  I may try to sneak out with my muzzleloader too.
Post by: peternap on May 20, 2009, 08:21:21 PM
I think you'll have a ball with it Don. A hint on cleaning. Use Blue windshield washer fluid. Works better than anything else I've tried.
Of your going to pull the breech plug, get a plug wrench. It will shave you lots of scratches and rounded corners.
Post by: MountainDon on May 20, 2009, 11:15:52 PM
Thanks Peter.
Sent you a PM Frank.
1 in 48 twist Frank; a compromise.
I have a couple hundred balls, 100 bullets, 3# of pyrodex select rs, 400 caps; I'll try out different loads. Ought to keep me busy.   ;)
#11 caps are pretty loud!!!     ;D
Post by: glenn kangiser on May 21, 2009, 12:15:38 AM
One of these days I hope to get a muzzleloader...just in case.
Post by: muldoon on May 21, 2009, 12:39:38 AM
nice looking grass.
rifles ok too  ;)
Post by: MountainDon on May 21, 2009, 10:02:53 AM
Quote from: muldoon on May 21, 2009, 12:39:38 AM
nice looking grass.
Synthetic turf
:D :D
Post by: MountainDon on May 21, 2009, 11:54:58 PM
Interesting video; A demonstration of an American Caplock Rifle.
http://www.youtube.com/watch?v=OleGFPx-6Ak
and...  A demonstration of an American flintlock long rifle.
http://www.youtube.com/watch?v=xH4VMIlQhFM&NR=1
1 more (flintlock)
http://www.youtube.com/watch?v=kExAte9DMNs&feature=related
Post by: peternap on May 22, 2009, 07:55:31 AM
I think your hooked already Don.
Start keeping your eye out for a smooth bore barrel. If you can find one, you have all the gun you'll ever need. Note I said need....not want! [rofl2]
Post by: Phssthpok on May 22, 2009, 08:42:42 AM
Quote from: peternap on May 22, 2009, 07:55:31 AM
Heh...my all time favorite exchange with an anti gunner:
Anti: "Nobody needs (x number) guns!"
Me: "It's never been a question of NEED."
(later)
A: "So, just how many guns do you have?"
M: "On me?"
A:  [shocked]
Post by: NM_Shooter on May 22, 2009, 09:08:34 AM
Hi Don,
You probably know a lot of this already as you like to be informed  ;D
I thought that the guy on the video did a couple of things I wouldn't.  He kept his body very close to the muzzle as he was pouring the powder in.  If that was a recent reload, there could have been charred cloth or some embers remaining in the bore as he poured powder in.  It is not a bad idea to swab out the bore with a cleaning swab in between shots.  After 3 to 5 consecutive shots, it gets pretty sooty in there and becomes hard to seat the ball.  Plus, swabbing tamps out the embers.
Mark your seating rod in a couple of different places depending on your load.  This will let you know when you have fully seated the ball, and protect you against placing a double load.
I know the guy was doing the period thing, but don't use spit on the patch.  Lots of better alternatives.
I could not believe that he was dropping the hammer and pushing on the cap with it.  I shot 1000s of rounds through my caplock, and never had to do that.  Granted, I was not using 130 year old caps.   ::)
Muzzle loaders are a complete hoot.  Be prepared to need a shower when you get home.  Don't leave your food out uncovered at the range. :)
Post by: MountainDon on May 22, 2009, 10:31:32 AM
Thanks Frank. I had picked up on the cap loading thing right off. I have the T/C manual and they are very repetitive and thorough about safety while handling a muzzleloader from the importance of never pouring powder direct from the flask into the bore, where to keep the muzzle directed, marking the ram rod, loading caps, etc.
Peter; elucidate on why I need a smoothbore barrel. Shot?
I saw a nice looking one (on another T/C). I also see there are barrels made for this with 1:28 (bullets) and 1:70 (balls) twists.
Post by: peternap on May 22, 2009, 12:44:44 PM
Quote from: MountainDon on May 22, 2009, 10:31:32 AM
If I recall, the standard smoothbore for that was a .54. That gives you something just shy of a 28 ga shotgun.
Make a capper with a piece of leather. Punch holes around the edge that will hold the caps and just thumb them on when needed.
