General => General Forum => Topic started by: Txcowrancher on April 18, 2009, 11:11:41 AM
Title: I wonder if these could be part of a footer or foudation??
Post by: Txcowrancher on April 18, 2009, 11:11:41 AM
http://dallas.craigslist.org/sdf/mat/1128235757.html
Title: Re: I wonder if these could be part of a footer or foudation??
Post by: Mandres on April 18, 2009, 11:25:11 AM
I saw those too and wondered the same thing.  I don't know how you would get them perfectly level in the ground though?  I also wonder how the building and permitting department would feel about it.
Post by: MountainDon on April 18, 2009, 12:05:29 PM
Those are huge!. I've only seen the shorter ones around here. If there was no inspection they would likely work. As for getting them level and well supported along their full length; well that's the biggest problem other than getting them moved and placed.
MTL, the easiest way to level them would be to pour a concrete footer, reinforced with rebar, and then set the concrete barrier in place.
Post by: rwanders on April 18, 2009, 03:16:28 PM
Careful preparation of your subgrade could get you close and then a little shimming could bring you to accurate level----they are known as "jersey barriers or dividers" because they were first designed and used by the New Jersey Turnpike Authority years ago.  They would make a bodacious cabin foundation!
Post by: rick91351 on April 18, 2009, 03:25:51 PM
About thirty years ago I drove ready mix truck for a couple years.  Back then that would have been not just a no but $$%#@@# no way.  I assume things are worse today.  Footings, piers and pier pads had to be poured in place.  However those puppies make one heck of a retaining wall.
rlr
Post by: firefox on April 18, 2009, 04:32:35 PM
Ok, this is crazy, but here goes.
Get 8 of these puppies. This is for a 30 x 30 foundation.
Grade the area flat but extend it aroundthe perimeter.
put a layer of crushed rock, followed by 2 to 4 inches of foam
making sure the foam extends out at the perimeter.
Put down a moisture barrier over the foam.
Set 6 of the barriers down on 6 foot centers, but first notch the ends
so that when you put the remaining two barriers in place at the ends of the other 6, the will roughly fit up close. Drill holes and put in rebar to pin the
ends together. Make a form and pour concrete to bond everything together
at the ends.
Place some concrete on the foam perimeter to keep the foam in place so that the extended foundation protects you against frost heave.
Now route some pex in the slots at the bottom of the barriers and seal in place with some concrete.
You can now route hot water from solar collectors to the bases of the barriers. The barriers will help store the energy and can be used for didtributing the heat.
I am assuming that the slot in the barriers is in the neighborhood of 4 to 6 inches, so that might be used for multiple posts and an aid to the leveling issues if any.
Ok I said it was crazy. But maybe it will give people some ideas.
Bruce
