Off Topic => Off Topic - Ideas, humor, inspiration => Topic started by: MaineRhino on November 12, 2008, 08:10:04 PM
Title: Which antenna to use for digital broadcast?
Post by: MaineRhino on November 12, 2008, 08:10:04 PM
Does anyone know what type or specific model of antenna to use for reception of HD channels in a remote area? We are probably over 50 miles to the nearest digital tower and get limited reception using a high quality indoor (digital) antenna. We get 2 HD stations if the weather is good.
I'd like to install an outdoor (pole mounted) antenna.
Title: Re: Which antenna to use for digital broadcast?
Post by: MountainDon on November 12, 2008, 08:21:48 PM
I can't comment on an HD antenna, but will relate my experiences with analog vs digital.
1. Here at home we're about 12 miles, direct line of sight to the antennas. We can see them. We get all the channels with the same antenna we've had for 25 years. It's about a $50 item, mounted on a  ft mast on the roof.
2. In the mountains we're about 38 miles line of sight. We cannot see the mountain where they are, let alone see the antennas. An antenna that is a step up from the home antenna brings in all the same analog stations with a little bit of snow on a couple of the lower channels (2 thru 5). Changing to digital with the same antenna we lose channels 5 and up, but 2 and 4 are excellent. I'll either need to raise the antenna or get a larger one. Presently the antenna is about 15 feet off the ground.
I've found two web pages that are great for antenna info.
http://www.antennaweb.org/aw/welcome.aspx
http://www.solidsignal.com/?xfermeth=directg&gclid=CIKt7ez-8JYCFSJIagodmH0HXg
Post by: harry51 on November 12, 2008, 08:32:34 PM
Be sure to check out the "Choose an antenna" function at Antennaweb. Also, google "smart antenna" for an interesting new device.
