Internet Finds for Designer/Builders => Referral Links => Topic started by: glenn kangiser on November 11, 2008, 02:17:05 AM
Title: Small cheap tankless heater
Post by: glenn kangiser on November 11, 2008, 02:17:05 AM
http://www.kk.org/cooltools/archives/003297.php
Thanks to Kevin Kelly - Cool Tools
Title: Re: Small cheap tankless heater
Post by: alcowboy on November 11, 2008, 08:51:22 AM
http://shop.ebay.com/items/_W0QQ_nkwZtanklessQ20waterQ20heaterQQ_armrsZ1QQ_fromZR40QQ_mdoZ
I thought maybe you guys would be interested in this.
Post by: wjbates1430 on January 10, 2009, 12:34:23 AM
Bosch makes a LP/NG tankless that needs no electrical hook up it has a micro water wheel that provides all the electric the igniter needs to light the burner. So as long as you have water flow you have hot water.
Post by: glenn kangiser on January 10, 2009, 12:48:12 AM
w* to the forum.  We have the earlier model of that Bosch - the HX125 LP.  We like it.  It is in a more permanent category allowing about 2 fixtures to run at once and around $600.  I don't know if they make a smaller one though.  It has been superseded though.
Post by: DirtyLittleSecret on February 21, 2009, 09:49:43 PM
There is also the Ecco Temp L10 (deluxe model) on sale at Amazon for about $240.
Specs seem to elude that it may be more appropriate for cabin/temp res use than the L5.
Though the L5 has a lower required psi (20 psi vs 30 psi) which could make a difference if "gravity feed" is an issue.
