Please add your general location to your profile so that anyone who see's your postings is able to instantly help better, help themselves better or have an idea of conditions and where you are coming from.
It's easy.
Click Profile above/Forum Profile Information/fill in personal text or signature with your location and or Signature quote, point to make etc.
At least get your general area if you don't want to be more specific.
Just seeing if it worked.
guess not
Doesn't work under location
Location only shows when someone clicks your profile. A couple lines above that is Personal Text. It will work there.
Testing
Excellent idea! It sure helps at times. :)
I got it from the diesel truck forum where we all put all the modifications and features of our truck so you know wnat you are dealing with and how to better help the person you are talking to or they you.
Testing.
Testing again after failed test.
Upper left side of the screen is a box that says modify profile. Click profile information within the box and you can put it on the line where it belongs.
GO HERE (http://countryplans.com/smf/index.php?topic=4973.msg61879#msg61879) for step-by-step instructions on how to implement this
Don comes through with a tutorial again. Thanks, Don.
Obviously I forgot to go far enough to mention the Change Profile button. d*
The Devil is always in the details.
testing
test
OK, I think it worked....
We got you, Ailsa.
...and - this is already proving helpful. So much easier to think of the conditions you are up against when we know where you are.
