General => General Forum => Topic started by: peteh2833 on July 29, 2008, 04:36:52 PM
Title: Bridging ?
Post by: peteh2833 on July 29, 2008, 04:36:52 PM
I'll be starting my Joists and Sub Floor next week on my 20x30 1.5 story. The ? I have is if I have a steel beam running down the center and the joists will be spanning 10 feet to the center beam which bridging should I use and where? Should I solid block over the steel beam where the Joists are sistered and then use metal bridging on either side of the center beam? Thanks Pete
Title: Re: Bridging ?
Post by: PEG688 on July 29, 2008, 09:10:00 PM
I'd say  block over the beam and your good. 10' of span is nothing , if you decide to use bridging , I'd use metal brigding from Simpson , attach the  two pieces to the joist tops , MAKE sure they do not touch , at least 1/8" gap between the two , nail them to the joist bottoms AFTER the roof is shingled , so the floor is "loaded" when you nail it off. Again insure they pieces do not touch , if they do they will squeak.
  (http://www.strongtie.com/graphics/categories/LTB-bridging_misc.gif)
Link : http://www.strongtie.com/products/categories/bridging_misc.html
G/L PEG
Post by: peteh2833 on July 29, 2008, 09:24:23 PM
So I can just block the center and not worry about the rest.
Post by: PEG688 on July 29, 2008, 09:44:43 PM
Quote from: peteh2833 on July 29, 2008, 09:24:23 PM
Yes it's only 10 feet between the outside wall and the beam , your using "I" joist right? You the guy who asked about the wood rim used with engineered joist aren't you?
   You might try  starting a thread about your place then keep all your questions in one place it really helps me at least , keep track of what "job" we're talking about.
  If we don't see the question on that original thread , then ask a specific question here in this section.
That makes it easier to manage IMO for who's doing what , with what , etc etc .
Just a thought.
  G/L PEG
Post by: PEG688 on July 29, 2008, 09:46:26 PM
With "I" joist we don't even block over the beams , UNLESS it spec'd / incuded in / with  the engineering of the floor system.
Post by: peteh2833 on July 30, 2008, 07:00:37 AM
No I'm not the guy with the I Joists. I using 2x10x10's. Thanks. Here is a link to the thread I started about the building process http://countryplans.com/smf/index.php?topic=3252.0 Thanks Pete
Post by: PEG688 on July 30, 2008, 08:29:36 AM
Quote from: peteh2833 on July 30, 2008, 07:00:37 AM
Ah OK. I still wouldn't use bridging on that short of a span , I would block over the beam.
Post by: peteh2833 on July 30, 2008, 06:31:57 PM
Thanks, that is what I figured I would do. Thanks so much for the insight. Pete
