General => General Forum => Topic started by: lockman on September 17, 2007, 06:55:33 PM
Title: Building over stumps???
Post by: lockman on September 17, 2007, 06:55:33 PM
First of all, I'd like to say hi to everyone out there. I've been reading these forums for awhile now, but now I have a question that I can't find an answer to. I recently bought some land that I'm wanting to build a small place on. There's already a road going thru it so the only trees that need to be felled is where I'm going to build. There's quite a few, but they are all pretty small, 3-6 inches. My question is do I need a dozer to push em over and uproot em, or can I just cut em with a chainsaw and build over the stumps? Thanks for any help.
Title: Re: Building over stumps???
Post by: PA-Builder on September 17, 2007, 07:55:02 PM
Are you planning on a concrete perimeter foundation, pier foundation ? ? ?   I'm assuming you're not planning on a concrete floor over the stumps ?   Please provide a little more information.
Post by: lockman on September 17, 2007, 08:23:22 PM
Pier foundation....
Post by: tanya on September 17, 2007, 09:00:56 PM
Sure you can build over the stumps when I lived in Hawaii everything was on piers and set over anything tht wouldn't couldn't move but do you want to build over the stumps is another question.  They will cause all kinds of problems and be harder to deal with once you build bugs will be drawn to them first of all and then there will be the little sprouts coming up and the roots will still try to grow and throw the whole thing off kilter.  Since they are small you wouldn't have any trouble with a dozer plowing them off or you could just build a  fire over them and they will burn off.  If you have the cash up front the dozer is going to be your best bet I would guess but I don't know much and there are real builders here.
Post by: MarkAndDebbie on September 18, 2007, 04:05:21 AM
If you are going to be on septic, you'll need something and/or someone to dig your lines and tank. My guy used a backhoe and bobcat. Those machines will make quick work of the small trees. Leave them high to get good leverage.
Post by: lockman on September 18, 2007, 06:17:16 PM
Thanks for the replies
Post by: StinkerBell on September 18, 2007, 11:54:28 PM
My only concern would be if your area has termites. They like to live in stumps, so do ants including carpenter ants.
Post by: skiwest on September 19, 2007, 10:44:32 AM
If little stumps a bobcat will make short of of them.  While your at it should scrap first couple of inches of top soil to remove organic matter .  If you don't remove sumps you'll be hitting a lot more roots when you dig for your piers.
Post by: lockman on September 19, 2007, 06:17:15 PM
Well, I called my uncle (who is in the excavating business) and got him to go look at the property. He told me he'd level out and widen the road goin thru the property, and clear all the trees I wanted down for 450.00. I thought that was pretty good, so I told him to have at it.
Post by: glenn-k on September 19, 2007, 08:05:41 PM
Sounds like a real bargain.
