Hi, found this site ,wife says were going to try it for our next chicken house
http://www.strombergschickens.com/starplate_building_system/starplate_index.php
I have a set of those, never set it up.
For a while I wondered if one could make a tiny house out of them--kind of the size of the the London flat that Glenn mentioned in Narrow Houses.
Here's a link to a video constructing and then de-constructing a small dome using a similar fastening system.
http://www.notreallyrelevant.com/Pico_Azores_Geodesic_Dome.html (screenshot below)
And good luck getting the code inspectors to pass you. ::) After that the main problem is sealing the panel joints so it doesn't rain inside. Glenn, you could weld one up in no time, subbing steel for wood. :) Spray the inside with Icynene? :-/
Bucky would be pleased.
Welcome to the forum, TW - seems it ought to work fine for a chicken house. Please post some pic's when you get going if possible.
