General => General Forum => Topic started by: chatycady on October 29, 2006, 09:07:27 AM
Title: Re: Little Log cabin 20X40 1 1/2
Post by: chatycady on October 29, 2006, 09:07:27 AM
We will be putting in a wood stove and also a claw foot tub in our log cottage and were wondering if we need to re-inforce the floor. The I-Beams are 16" oc and span the width of the cabin.... around 19'. They are within the required limitations as we used t&g sturdifloor, glued and screwed down.
If we need to re-enforce the floor, will it be blocking between the joists? The full length, span of the joists? Anyone with suggestions will be greatly appreciated.
chaty
Post by: glenn kangiser on October 29, 2006, 10:51:08 AM
Just making a guess here, Chaty, but I don't see either of them seriously exceeding the live load of the area they cover, so I would assume that you might only need to reinforce the areas where there will be point loads such as reinforcing under the points where the claw feet will contact the floor.  Similar for the stove if its a heavy one.
In reality, with the strength of the floor you have built including glued and screwed down, I don't see how there could be much problem.
Possibly others will know more about this.  Probably PEG -- he has experience in everything having to do with building. :)
Post by: John Raabe on October 30, 2006, 04:24:29 PM
You can block between the I-joists and, if you want, reinforce the webs of the I-joists with 2x material. Doing both in the area immediately under the tub would provide insurance against a bit of flexing in that area. This might be important if you will do tile flooring.
Post by: chatycady on October 30, 2006, 08:02:52 PM
Thanks! I'll do it!
