General => General Forum => Topic started by: builderboy on September 21, 2006, 09:00:25 AM
Title: Insulating floor
Post by: builderboy on September 21, 2006, 09:00:25 AM
I'm looking at insulating my floor which will vary from 1 to 4 ft above ground. A previous topic suggested covering the bottom with tyvek, pegboard or osb/plywood with vent holes drilled. I'v got a chance to get a bunch of vinyl soffit free. It provides the venting and won't wick moisture like masonite pegboard. Since it's free it's my cheapest option. I'll only need to buy about 20% of my requirement. Any bad consequences here?
Title: Re: Insulating floor
Post by: jraabe on September 21, 2006, 10:46:43 AM
That would be a sturdy material that will not trap moisture. Be sure the insulation fully fills the joist cavity and the soffit material holds it up against the subfloor.
Good find!
Post by: Chateau_Prideaux on September 21, 2006, 01:58:35 PM
Assuming that you're using batts, which way should the insulation's backing face? Do you need to install this before laying down the subfloor decking?
Post by: builderboy on September 21, 2006, 02:14:55 PM
Vapor barrier to the warm side of the bats ie between bats and floor decking. I'm doing it from above before installing the decking because I have little room to work underneath. The trick is keeping the bats dry until the building is weather tight. Got my tarps ready for rain!!
