I need some extreme or not so extreme ideas on the simplest way ,labor-wise, to build a house!!!
lets assume that I want to do most of the labor myself- with an extra set or two of hands available when needed.
example, I could sheath the house with OSB, but it would be easier and faster to sheat with foam . the price would be about the same, and the lighter foam would provide insulating value in addition to being easier to put up. Foam also wouldnt rot over time being exposed to moisture.
the ultimate goal is to build a house for LESS than $50 a square foot.
I am already planning to include money saving ideas like
1. building a rectangular house with no bumpouts or notches.
2. forgoing the garage -.my cheap cars dont need a separate room to be stored.
3. using modular design. 4 foot modules and everything lands on 2ft oc studs
4. inexpensive countertops and kitchen/bathroom components.
5. avoid doors where not necessary
6. avoid windows where unnecessary - eg, no windows in bathrooms or clothes closets.
7. building UP! two story instead of one story
8. straight run stairs
9. Shed roof is the cheapest
10. no overhangs
11. steel sheathing
12. steel roof
13. compact plumbing design
14. 32' or shorter span
Ive been thinking about this for a year and Ive already incorporated a lot of things but I feel like I havent done enough to get down to below $50 psf
what else am I missing?
one area of concern is interior walls. drywall is CHEAP but requires finishing, which Ive heard is very labor intensive. What are easier alternatives? anything that doesnt require finishing?
I look forward to some ideas.
Things to think about;
Foam sheathing, sheathing also provides bracing, foam does not.
Watch your roof with your module spacing, I see people sweat over the walls and blow that savings at the roof.
If no windows in a bath mechanical ventilation is required
I avoid straight run stairs whenever possible, that is a long fall
Shed roof is cheapest on narrow buildings
Overhangs protect siding and walls, pay a little now or much more later
Steel siding over foam sheathing does not create bracing
I like lots of wood with some drywall, but I have a sawmill and shop, it doesn't get much cheaper than drywall, esp if you finish it yourself.
wider spans.. look at the siding cost on your shed roof design, gable trusses will be a cheaper overall option.
economize space, avoid hallways and other "wasted" spaces when possible.
A sf price goal is deceptive. I can drive sf price down by simply adding large low detail spaces. A smaller house will have a higher sf cost but a lower overall cost. And remember cheap is not necessarily cheap over the life of the house.
Time is money...a single-level ranch or shotgun-style house with panel (T-111) siding, a low-pitched truss roof, drywall, carpet, sheet vinyl, particle board cabinetry, MDF doors/trim, economy fixtures, is the cheapest possible...AKA "tract home"...
Quote from: Don_P on February 22, 2020, 10:18:59 PM
Thanks for the feedback don. Appreciated.
To address some of your points:
Foam sheathing can be used with sheet metal x braces, or plywood at the corners so bracing should not be a problem.
I guess with operable windows in the bathrooms then a vent is not required? Great point. I'll have to compare and research both options
Regarding straight stairs. I hear you but they save a considerable amount of space. I think I was able to reclaim more than 100 sf by switching to straight run from u shaped
When you say look at the siding cost of the shed roof- I think you mean see which one has more wall area? I'll have to look. I'm looking at a very low slope shed roof so I think it wins but I'll really have to compare. Very easy to do in SketchUp.
Quote from: akwoodchuck on February 23, 2020, 12:21:49 AM
Amen to that! Time IS money and that's why I'm looking for the least time consuming options that also take the least amount of skilled labor.
Eg epoxied concrete floor on the first floor. I've seen a plywood second floor and I thought it was a great idea as I think it would save even the time and cost of installing carpet?
Other things im thinking to save time. Does the first floor ceiling need drywall? I've seen exposed joists (usually more expensive builds) but wouldn't this be a way to save time and money? That look is not for everyone but I personally like the more industrial esthetic.
Can I pour a slab in sections? I've seen it done for garages can it be done for a house? Diy slab on grade could save thousands.
Etc
Oh I was also going to say-where can one find a good quality t1 11 nowadays. What I see at the big box stores, is junk
Roseburg and Georgia-Pacific are both good...the LP stuff I wouldn't use on a doghouse....
If this is inspected the drywall will be required on the ceiling for fire safety. Unless I am missing something ???
A garage will protect any vehicle from rodent damage. Some of my offgrid clients often start with a garage before the house for alot of good reasons.
Quote from: akwoodchuck on February 23, 2020, 03:23:27 AM
Thanks! I'll check them out. T111 goes up quick. I was thinking of already painted standing seam panels for the roof and walls but I'll look into the t1 11
Quote.... 4 foot modules and everything lands on 2ft oc studs
24" OC wall studs can make it more difficult to place things that need to or are usually attached to wall studs: electrical boxes, cabinets..... With 24" OC studs 1/2" drywall ban be wavy-ish, not as firm as you might like. 5/8" drywall might be better.
On that thought it can also be benefical when it comes to mounting cabinets to walls in kitchens and baths to install horizontal runs of 2x's at the height that would be used to screw the cabinets in place. That takes some planning but means you don't have to find a stud to hang the wall cabinets. Also good for attaching bathroom handrails.
Quoteeg, no windows in bathrooms
as was pointed out by Don_P there is the question of ventilation. As well, a windowless bathroom will require a light turned on every time it is used. Maybe not a big deal, but some folks have trouble turning off lights.
Quoteno overhangs
Overhangs are not just architectural details, they do provide better weather protection for where the wall meets the roof. That can be a point of water ingress w/o any overhang.
Speaking of roofs... where will this be located? In areas subject to high winds a hip roof is often better than a gable roof as there are no gables to be picked at by the winds. Winds flow over the roof better. Properly anchored roof trusses to wall top plates will help keep the roof on.
Quotedrywall is CHEAP but requires finishing
Drywall is a cost effective wall and ceiling cover. It can be done well by a DIY'er. There is a learning curve. Proper tools, an assortment of drywall knives of increasing widths helps a lot. Or hiring a drywall crew can be a good thing too as they can do a great job in a short time. Drywall, done right, is also a big help in air sealing the interior. Lots of air can escape into the attic space with lousy air sealing. It is my belief we should build for the long haul. A little spent now, maybe more time taken now, can reap energy efficiency benefits for decades. Even if something like T&G boards are used to be the cosmetic wall or ceiling finish in some areas, first installing srywall can result in a better sealed wall or ceiling. If you know ahead of time that certain areas will be T&G or something else, those areas only need taping and rough jointing. It is also required for fire protection in some areas.
QuoteI could sheath the house with OSB, but it would be easier and faster to sheat with foam
I am a big fan of using sheet sheathing like OSB and of foam sheet insulation on the exterior. Foam over the osb. The osb provides good anti-racking structural strength and the exterior sheet foam provides good insulation over the studs and all. The osb panel nailed to the studs and the top and bottom wall plate makes a strong wall.
I don't like T1-11 types of exterior finish siding especially when it is used as a structural element as well as cosmetic. After many years it always seems to have issues around the lower foot or so. At least that is what I see around me in NM. We are mostly slab on grade and the T1-11 failures occur along the lower wall edge. I think a layer of structural sheathing on the studs, under the weather-resistive layer makes for a better building with a longer lifespan.
I have done my own DIY concrete driveway sections and can attest to the fact that it is a lot of work; can take longer than you might think. But it is doable.
I agree with Don_P on long straight runs of stairs. Breaking the long run between two floors into two or three shorter runs can be safer. The space under the stairs can often be used for practical storage, as long as the underside area is finished with drywall to slow the spread of fire. That said I also like a single floor layout even with the larger roof area that entails. There are times in life when stairs may be a disadvantage. That may be just a personal choice. My sons' house, a three-story, has 6 runs, most with 5 or six treads.
I also agree with Dave about a garage being actually useful protection. But then I love my garage and wish it was bigger to provide more workspace.
What kind of HVAC system?
What is the overall size goal? The number of rooms and total livable square feet?
What climate zone?
Quote from: Dave Sparks on February 23, 2020, 11:23:30 AM
I hadnt seen any code saying this but i looked and it looks like if using i joists then there has to be a cover. i dont see anything if using 2x
good points. ive never used a garage but ive always lived in the city.
Quotegood points however i want to go with OVE framing for less thermal bridging
Quotethat wont be a big deal. LED lights consume an insignificant amount of energy
Quotethis is true. and the jury is still out on this one. i do see a lot of buildings with no overhang and no visible water damage
Quoteagree. this is in north texas. no significant wind loads. plan now is for a very low slope roof. I might go standing seam, or torch down roofing.
Quoteagree. ive had t1 11 on my current house. it lasted 30 years but i ended up putting vinyl over it.
Quotethis is encouraging
Quoteconventional heat pump system with exposed ducting combined with some ductless mini splits
Quotegoal is a 48x32 building with 4 bedrooms , and as many "Away" rooms
What climate zone?
Quoteclimate zone 3 a. hot humid with mild winters and no snow load
First of all you have to decide on a foundation. The material costs for a basement beam, floor joist, 3/4" subfloor, 16" OC exterior walls, exterior sheathing, 4/12 gable trusses, and roof sheathing should add up to around $6 sq ft.
1. building a rectangular house with no bumpouts or notches. GOOD IDEA
2. forgoing the garage -.my cheap cars dont need a separate room to be stored. GOOD IDEA
3. using modular design. 4 foot modules and everything lands on 2ft oc studs I WOULDN'T WORRY TOO MUCH ABOUT BEING ON 4' modules. A GIVEN LAYOUT MAY BE PERFECT FOR THE WALL SHEATHING BUT NOT BENEFICIAL FOR THE INSIDE WALL SHEATHING (drywall) OR THE ROOF SHEATHING
4. inexpensive countertops and kitchen/bathroom components. GOOD IDEA
5. avoid doors where not necessary ?? WHO PUTS IN EXTRA DOORS
6. avoid windows where unnecessary - eg, no windows in bathrooms or clothes closets. I CAN GET WINDOWS FROM AN AUCTION ALL DAY FOR $10 EACH. GOOD ONES, ANDERSON/PELLA/MARVIN. NO NEED TO SKIMP.
7. building UP! two story instead of one story IT DEPENDS IF YOU WANT TO WALK UP A FULL FLIGHT TO GO TO BED. IF YOU ARE BUILDING YOURSELF THE EXTRA HEIGHT WORK BECOMES A REAL PROBLEM.
8. straight run stairs I WOULDN"T WORRY ABOUT THIS. A STRAIGHT RUN WILL EAT UP 36sq ft. AN L-SHAPE WOULD EAT UP 45 sq ft of space.
9. Shed roof is the cheapest SHED AND GABLE TRUSSES ARE ABOUT THE SAME PRICE UP UNTIL 24ft. AFTER THAT THE GABLES ARE CHEAPER.
10. no overhangs BAD IDEA. THE HOUSE WILL LOOK TOO CHEAP AND OVERHANGS ARE USEFUL IN OTHER WAYS
11. steel sheathing I DON'T KNOW OF ANY STEEL SIDING THAT IS CHEAP. I HATE VINYL BUT IT CAN BE HAD DIRT CHEAP
12. steel roof SHINGLES ARE CHEAP AND IT'S EASY TO FIND A SPANISH SPEAKER TO DO IT CHEAP
13. compact plumbing design VERY GOOD IDEA, STACK YOUR BATHROOMS AND SHARE THE "wet wall" WITH THE KITCHEN.
14. 32' or shorter span YES. 32' IS PLENTY. IN FACT 28' WOULD BE THE SWEET SPOT FOR 12" I JOIST SPANS
You are down south, I can't see being too worried about thermal bridging.
I don't think I-joists need to be covered. Think of all the unfinished basements with exposed I-joists out there. I think you could have open framing but any rigid foam would need to be covered. I am in WI so we use the UDC but most everyone else uses the IRC.
I would sub out the drywall. Those guys can do it so fast. By the time you get to the drywall you are gonna want a break from the hard stuff.
I got new bath fans for $5 each from a building surplus store. No need to skimp on those.
In a couple years I plan on building a retirement "cottage" for myself. I will be doing it with cash so it will take all I have just to build a 30x40 shell with just the minimum required to get a CO. So that is very similar to your project.
"A sf price goal is deceptive. I can drive sf price down by simply adding large low detail spaces. A smaller house will have a higher sf cost but a lower overall cost. And remember cheap is not necessarily cheap over the life of the house."
I really hate the use of the SF price as if it's gospel.
My planned well will cost 10K no matter what size house. If I build a 600 sq ft house my well will cost 16.66/sq ft. If I build a 2000 sq ft house my well all of a sudden gets cheaper at $5 sqft.
Pretty much the same with my septic.
"I've seen exposed joists (usually more expensive builds) but wouldn't this be a way to save time and money?"
Google "painting exposed basement ceiling". I tore out the drywall and ceiling tiles in my basement and intend on painting it.
QuoteSWEET!!! the plan is a slab on grade foundation, unless there is something less costly out there.
Quotelol. my spouse seems to think rooms like the pantry or walk in closet needs doors.
Quotehow can you tell me you can get surplus windows for 10 bucks and then not share this auction is? :D
Quoteif i can figure out how to post an image ill post the floor plan. i looked at l shaped and left quite a bit of unusable space
Quotethats possible but how about with cut rafters?
Quotehouse has a modern/ancient (depending on how you look at it) esthetic
Quotecorrugated steel is $100/square, standing seam $200/square. Vinyl is in the same range around here. i like the steel because you can get the exact length ie 20ft where vinyl afaik tops out at 12 ft??
Quoteif i do a gable roof ill definitely do shingles. with low slope i cant do shingles
Quote from: WISteven on February 24, 2020, 07:18:02 PM
i was thinking of open framing for just the first floor, where there is no insulation. i could also do it for the second floor i think, if i put foam insulation above the deck i only need r19 to meet code, vs r38 if its on the "attic" floor
you make a good point about the drywall. maybe ill bite the bullet and sub it out. the problem is , since im not a GC , finding skilled, affordable labor is ...tricky. any tips are greatly appreciated.
i need to find a building surplus store!!! the ones around here are not actual surplus even if they say they are.
"thats possible but how about with cut rafters?"
There is much more involved with cut rafters (whether you go with 2x12's or I-joists) concerning loads and insulation. Trusses give you a free span underneath.
Quote from: WISteven on February 24, 2020, 08:51:34 PM
True. Although I designed the building to have a loadt bearing wall along the center line for this reason.
Speaking of trusses - that brings up another question- is traditional framing the cheapest?
Example. If you price Menards 2 ft oc trusses they come out more expensive than their 10ft oc post frame trusses. For a 48 ft build you need 25 trusses vs 6 post frame trusses yet their post frame trusses are only about double the price of the 2 ft oc trusses.
So should I be looking at post frame construction instead of regular stick built?
I decided to switch to a 4/12 pitch gable roof. lower cost shingles, lower cost insulation, etc.
it should cost about $2500 for the trusses.
Stairs eat space, period. My U-shaped stairs used about 64 square feet. I have a closet under the bottom, and another over the top, so some space was recovered.
I prefer large overhangs because they protect the walls and windows, keep rain away from the foundation, provide shade during the heat of summer, and they look better (just my opinion there).
One of my wife's few specific requests was an attached garage, so I obliged her. I have to live in this house with her, too.
My house is a simple rectangle with 5/12 pitch roof. Trusses are cheap. I used quality materials, such as ICF construction, Marvin windows, fiber cement siding, and a metal roof. Very heavily insulated. I plan to stay here until they carry me out toes-first. Our house is extremely energy-efficient, which saves money in the long run, and makes for better day-to-day comfort.
Our house certainly wasn't cheap, but it is durable, comfortable, long-lasting, and aesthetically pleasing. Building a house is a big project, and worth decent materials.
Thanks for posting mush.
Questions- who designed your house plan? What did it end up costing psf? I talked to an icf contractor and it was 15 psf just for the forms?
Like this discussion, have thought about this for years.
Low cost, easy to assemble, nice finish features.
Plywood is a time saver!!
Painted, stained, textured (batons), can be interior or exterior finish.
A square will enclose the most area with least material!!
So 24x24 or 12x48??
Lot of material, for walls that is, , let's go square.
To be continued ...
Paul
Batten, board and battegot it spelled right this time!!
There's almost always qualifiers it seems like. Watch the dimensions of the framing members as spans change as well.
Batten, is a better spelling
I think 2x6 floor joists, studs cut so 8 foot plywood goes to of top of the top plate to bottom of floor joist, makes plywood siding simple, but gives 88 inch ceiling height
Nice open floor to fabricate roof trusses, 5/ 12 pitch, really 22.5 degrees, make cutting easy
Wide eaves built into trusses
Adjust eaves for easy plywood application, 8, 10, 12. 14 ft pliss gap for ridge vent!!!!
There is where I was going with things to think through. a 2x6 floor joist spans around 8' so there would need to ba rows of girders and footings at those intervals, a 2x12 can span around 16' so that is one way to hop over that pier and beam cost at the expense of larger joists. And then I've been up to about 24' clear span on engineered joists, just more stuff to mull over.
You can get T-111 siding in longer lengths than just 8' too....
Great discussion guys.
88 inch cooling height is way too low.
I'm looking at minimum 9 ft ceiling height.
Thanks akwoodchuck.i was wondering if t 1 11 is available at longer heights. Good to know it is. I'm revisiting it as an option just because it saves a step. Anything that saves labor should be looked at.
I have done the solar power systems on over 250 offgrid homes around the planet. Many are like the folks asking here for ideas.
My top 3 for advice.
#1 Build something that is marketable. People want a minimum 3bd 2ba or the ability to do that later. Expandable needs to be thought out on a smaller than normal design.
#2 Build something that is not overly expensive if you ever want to recoup. Stay in the median price range. Offgrid homes can be hard to get loans on and to sell.
#3 Build something that is legal and meets the norm for your location. If it is not inspected take pictures of each stage.
Re: Just how straight is kiln dried lumber?
« Reply #2 on: Today at 02:49:46 PM »
QuoteModifyRemove
Some good thinking, I am now looking at off grid properties, and am thinking of building a 12x36 shed roof 'cabin'.
I want rodent proof floor. So... double the bottom wall plate, floor is joists and 3/4 " plywood. On top of floor is laid 3/4" rigid foam insulation, on top of that another 3/4" layer of plywood.not a big r value but a continuous one. Thoughts on this please.
Ty
Paul
Btw 3 great things above
Dave sparks, soo good those three, I will keep them in mind,
I went to school, SUNY @ Buffalo, 1976, industrial engineering, likely not you, Paul S
If you're looking for a simple house build and doing most of the labor yourself, focusing on material efficiency and cost savings is key. I went with a slab-on-grade foundation for my build since it eliminated the need for a basement or crawlspace, reducing both labor and material costs. For walls, structural insulated panels (SIPs) were a great time saver, quick to install and energy efficient. Roofing was another area where I cut costs by choosing a low-pitch design with asphalt shingles.
If you plan on holding the property long-term, you might benefit from a cost segregation study to maximize tax savings. I came across this option through https://costsegregationguys.com/ (https://costsegregationguys.com/), and it can be a big help in getting more cash flow from your investment.
Most people try to save money with cheaper versions of expensive things. But the real trick is to cut out anything that's unnecessary work. Flat, square, simple. Durable, not fancy.
Focus on systems that do multiple jobs at once — like SIPs (structure + insulation) or plywood (sheathing + wall finish). Use what's fast and good enough.
Great points on the SIPs and slab-on-grade. That combination definitely shaves off a ton of framing time and foundation headaches when you're doing the heavy lifting yourself. Low-pitch asphalt is a smart, budget-friendly move too.
Totally agree on the cost segregation front.. it's a massive cheat code for freeing up cash flow if you're holding the property as a rental or investment. Just need to have REPS status if its a long term rental and of course need to materially participate.
I saw you mentioned Cost Segregation Guys. I actually looked into them on my last build but ended up going with SMF Cost Segregation Advisors instead. I found SMF's process to be a bit smoother, mainly because they ran a free preliminary benefit analysis for me right out of the gate and I had a pretty nuanced tax circumstance as I needed to do a lookback study. It was incredibly helpful to see the exact estimated tax savings on paper before I had to commit or pay for the actual study and there was some adjustment they did to account for all the depreciation I didn't claim in the years prior..
Just throwing it out there as another option for anyone reading the thread who might be weighing their choices on the tax side. Good luck with the rest of the build!
