This is very accurate.
Just plug in your zip code and it tells you which gas stations have the cheapest prices (and the highest) on gas in your zip code area. It's updated every evening.
http://autos.msn.com/everyday/gasstations.aspx?zip=&src=Netx
Be a good neighbor and pass this along
It got most of them around here but didn't give me any good news --- lots of old gold mines around here but all the oil companies seem to want to do is give us the shaft. Here's to record profits without being gougers. [smiley=thumbdown.gif]
Gas basically doesn't get cheaper until you get either to Savannah or Florence. And neither is worth driving the 30+ miles each way to Savannah or the roughly 50 each way to Florence, unless you have a truck with two fuel tanks, and even then it might be iffy, given the gas mileage those things usually get.
Worth while filling up if you are there, mind you. Difference has been between 10 and 15 cents a gallon.
An old thread but a good tool woth passing along especially these days.
It's not very accurate. It shows Fasmart at 3.27 for unleaded, it doesn't even show WaWa at 3.19 directly across the street.
