General => General Forum => Topic started by: Arky217 on February 07, 2012, 11:31:48 PM
Title: Will this work ?
Post by: Arky217 on February 07, 2012, 11:31:48 PM
I am wanting to keep my metal roof from being penetrated by multiple vents.
I was wondering if this arrangement work; tying all the vents together in the attic and going out the gable end of the house.
(http://www.diychatroom.com/members/arky217-86953/albums/all-pictures/5045-drain-vent-600-x-280.jpg)
Arky
Title: Re: Will this work ?
Post by: Bob S. on February 08, 2012, 12:03:11 AM
I have a similar question. Would it work if you ran it up into a cupola at the roof ridge? You would have to make shure that the cupola was not vented to the attic.
Post by: MountainDon on February 08, 2012, 12:15:28 AM
I don't know why so many folks are afraid to drill or cut holes in their roof. The available rubber or silicone boots with a dead soft aluminum flange within the molded boot work very well on a metal roof.  ???
Post by: MushCreek on February 08, 2012, 06:03:12 AM
Since we're on the topic- How do you flash the boot to the metal roof? I ran into this on my barn. I had to put the vent in after the fact; the roof was already on. The base of the boot was a good deal wider than the space between the ribs, so I cut it down. I still don't know how to cut the roofing to get an overlap. Had I been able to do it during the roofing, I guess I would have cut two pieces of roofing so the upper could overlap the lower, with the boot at the transition. For the short term, there is no boot- just half a tube of silicon to keep the rain out. I do need to fix it, though. The other problem in my case is the very steep pitch- 12/7. It's the lower part of a gambrel. All of the boots I found were for 12/12 or less. Any thoughts?
Post by: Don_P on February 08, 2012, 06:47:41 AM
I don't like roof penetrations myself, what Arky is proposing looks like an allowable revent to me.
Can you run up the rafters to the upper pitch on the barn?
