General => General Forum => Topic started by: paul s on July 03, 2011, 08:56:41 AM
Title: Buildings under 200 sf - was the winner ever built?
Post by: paul s on July 03, 2011, 08:56:41 AM
I really  like the winning entry for a lot of reasons.  Simple to build, its accessibility, and open plan.  I am thinking the tall  ceilings would make if "feel" rommy inside.  Has any one built this small home?
  would  like to se photos if any one has.
Title: Re: Buildings under 200 sf - was the winner ever built?
Post by: John Raabe on July 03, 2011, 10:23:22 AM
I haven't seen photos of any built projects but your question gave me a chance to revisit this great little design. Everyone would modify this to their own needs. Here are some changes I would make.
(https://i1009.photobucket.com/albums/af219/countryplans/markc.jpg)
The pocket doors can't really cut through the pole framing so I would do a set of inward swinging french doors and an opening window near where the table would be. The bath could be redone with a sink and eliminate the side door and ramp if wheelchair access is not needed. I would probably platform (stick) frame this rather than use a pole frame. Use full height triple built-up stud posts between the big upper windows then sheath the corners for bracing panels.
The movable front deck will be quite a challenge even in the size shown. I would build a larger permanent deck and deal with security issues with lockable shutters on the french doors.
Post by: paul s on July 03, 2011, 02:44:51 PM
More good ideas, My thought too to  do without the side door.  Was thinking sliding glass door for the front  entry to eliminate any door swing.
I have to think with the windows up high the inside would be light and airy.  I like the idea of  a full width deck, could be roofed and screened in in the future.  i know defets the 200 sq ft.  but by then the bushes may have grown high enough  to hide things.
Post by: John Raabe on July 03, 2011, 03:28:19 PM
 :D :D :D
The interior would be quite airy and there is enough room for a storage loft over the kitchen/bath area of the back wall.
The slider could work but I was trying to stick to the approximate 5' spacing on the vertical supports. That would not leave room for a slider of sufficient width to get thing in and out.
Post by: paul s on July 03, 2011, 03:36:27 PM
Have to agree on the sliding door.  I am thinking of using this design as a shed and stick framing it.  Framing for windows and doors in the future.  For future expansion framing in a front porch with the roof just below the upper windows  and maybe 8 feet wide and the length of the house 20 feet.
