General => General Forum => Topic started by: Bretttf on May 11, 2011, 03:08:11 AM
Title: Plywood floor- glue & screw or nails only
Post by: Bretttf on May 11, 2011, 03:08:11 AM
Title says it all really.
I'm putting an 18mm or 3/4" plywood floor on my joists.
Is it best to glue and screw or just nail in place?
Any comments or problems with either please?
Brett
Title: Re: Plywood floor- glue & screw or nails only
Post by: Redoverfarm on May 11, 2011, 06:09:23 AM
Generally most contractors will glue and nail.  The nails should be "ring shank" though.  Some have used screws but it is time consuming and for a contractor time is money.   Screwing is probably the best approach to prevent squeaks later.  In addition pick the right adhesive for the sheeting.  Advantex recommends a polyurethane based glue rather that regular construction adhesive.
Post by: Bretttf on May 11, 2011, 01:15:38 PM
Thanks for that.
Would an exterior water proof PVA glue be ok?
I can get loads of that free!
