a small cabin in mn
Started by theshack, September 26, 2007, 11:37:42 AM
 ;D ;D
I built a small shop building using their info.
hnash53
Thanks for the input on trusses.
But the ones that Mark made are kind of a cross between trusses and rafters, and I can see that they don't have birdsmouths.
The bottom chord of a typical truss, being horizontal, of course don't have or need a birdsmouth.
But do scissor trusses need birdsmouths, since the bottom chord is not horizontal?
Seems as though any truss or rafter will need a birdsmouth.
Ay?
Quote from: hnash53 on November 22, 2007, 12:07:50 PM
#1: But do scissor trusses need birdsmouths, since the bottom chord is not horizontal?
#2: Seems as though any truss or rafter will need a birdsmouth.
#3:   Ay?
  #1: I've never seen a professionally manf. truss with a true birds mouth.  They have a flat spot / level place that generally is made to fit on the top plate so it makes a "point/ joint / corner " for the wall /  ceiling break .
You may have to look at  a couple of different types of   huricane clips , such as H-1 or H 2.5's or a combo of the two where interior walls get in the way of a standard H-1 clip.
#2: generally yes , always no , so it DEPENDS! ;D
  #3: Ay?    AH yes  hmm  hmm
