I have been researching building with vertical logs on the the internet and was lead here through a pinterest link.
Some background:
We are purchasing 30 acres in the northern lower peninsula of Michigan. 25 or so acres are wooded with pine that was replanted in rows decades ago, the other 5 are hardwoods. The pine trees are tightly spaced but look to me to be easily large enough to build with.
I am trying to find plans to build a vertical log cabin that will pass muster with a building inspection. Something around 800-1000 square feet. The plan would be to use logs harvested from the property. I am hoping the folks here can help point me in the right direction.
Help! and thank you!
A little 2nd hand knowledge of exactly that, and in that area. An engineer's seal was the path forward, they chose a different direction. You've obviously got plenty of vertical capacity. Weak in lateral bracing, racking, so that needs to be developed in the design somewhere.
