Author Topic: 28 X 40 California Redwoods  (Read 90250 times)
Offline ChugiakTinkerer
  • Senior Member
  • Building a remote cabin in Alaska
Re: 28 X 40 California Redwoods
« Reply #175 on: May 20, 2020, 05:15:25 PM »
Looks like a very productive weekend.  Congrats!
Offline MountainDon
  • Administrator
    • My 15.75 x 30 Jemez Cabin
« Reply #176 on: May 21, 2020, 05:29:04 AM »
Nice to see progress
Offline pmichelsen
  • Senior Member
  • Along the Eel River, Northern CA
« Reply #177 on: May 27, 2020, 05:23:22 AM »
Did a family trip for Memorial Day weekend, main things accomplished were replacing the water heater that had gone out on me the previous weekend and framing in another wall.
Hopefully my next trip up I can install some z flashing at the bottom of the walls and then sheath them as well as frame in the last two walls. Feels good to be making progress on this project. We will also be setting the generator in July, I know my buddy will be happy to finally get it out of his warehouse. Our neighbor up there is going to let us use his backhoe to pick the generator off the trailer and set it into place.
Offline pmichelsen
  • Senior Member
« Reply #178 on: July 01, 2020, 05:55:59 AM »
I framed up the last exterior wall a few weeks ago and now I'm ready for sheathing. The family and I are going up tomorrow after work for the long weekend, I should have enough time to get the sheathing installed and the area secured. My buddy and his family will be at the property so I'll take advantage of having another body and move the washer and dryer down there over the weekend. They have been stashed in our guest room for just about five years now, hard to believe it's been that long.
I'll spend the rest of the year working on shingling, waterproofing, and running water and electricity to the space. I also need to make a door, I'm considering just welding something up so that it's secure.
Offline pmichelsen
  • Senior Member
« Reply #179 on: July 06, 2020, 07:20:10 AM »
We spent the long weekend at the cabin. Friday morning I was able to get all of the flashing and sheathing installed then Saturday morning I got all of my felt up. I feel pretty good about how it sits now, I don’t really want to shingle until I figure out how I want to do the deck and what the heck I’m going to do about the section of cabin near the tree. I’m trying to design something that will allow me to brace back to my new foundation. There isn’t a lot of weight up there and if I can avoid putting anything in the ground that close to the tree I’d like to.
For the most part things went pretty smooth, the only issue I had was making some bone head mistakes when framing my walls so I had to add in some blocking, not a huge deal just took some time. Also trying to hang my felt alone was a bit of a challenge, my wife tried to help with the first course, but our daughter is almost two and doesn’t want to sit still for anything.
Starting sheathing:
Felt going on:
It’s hard work being a dog:
Offline pmichelsen
  • Senior Member
« Reply #180 on: September 09, 2020, 04:28:53 AM »
I was at the cabin over the weekend, main focus was hanging out with the family and relaxing, but I was able to accomplish a few things while there.
Finally had a chance to patch all of the snap tie holes with some Ardex. Once that setup I did a coat of HLM 5000 and now I have to decide if I’m going to do additional coats or if I’ll just install the dimple board.
Two weeks ago I had 13 yards of 3/8” rock delivered to use as back fill and I brought up ¾” drain rock to use for my French drain. I’m getting close to being able to back fill and get the exterior water tight.
« Last Edit: September 09, 2020, 05:22:38 AM by pmichelsen »
Offline MountainDon
  • Administrator
« Reply #181 on: September 09, 2020, 10:29:03 AM »
Looks very different from what you started with.   [cool]
Are the fires any ore or less immediate danger?
Offline pmichelsen
  • Senior Member
« Reply #182 on: September 09, 2020, 12:56:57 PM »
Thankfully we're out of the danger zone, though we barely missed one on the way home. The Oak Fire is burning outside of the town Willits, we drove through at 11:30am and the fire broke out at 1:30pm and completely shut the hwy down. Just checked and it looks like the hwy is still closed. Willits is about 45 minutes south of our place. It's pretty scary out there.
Offline pmichelsen
  • Senior Member
« Reply #183 on: February 05, 2021, 05:00:44 AM »
I've been going back and forth on what to do for a door to the basement. It's a weird size, really should have thought more about that when framing the opening, and I think my original thinking was that due to the height it was going to need to be a custom door anyway. Originally I was going to weld a steel frame and skin it with some light gauge steel, and use some channel to make the door frame. I started to think about how long that was going to take me and I decided to explore having a custom steel door/frame made, one saying that always stays in the back of my mind, "you can always make more money, you can't make more time".
The custom door came in about what I thought it would ($1,500) so I went ahead and ordered it. This way all I need to do is paint it and install it. The door should be done next month and I'll be able to get it installed and have the downstairs a little more secure, I've been a bit nervous as I'm storing a generator, welder, and some tools down there and the only security is eight screws holding the plywood on the wall.
Offline pmichelsen
  • Senior Member
« Reply #184 on: March 23, 2021, 04:39:05 AM »
Spent a few days up at the cabin this last weekend and finally installed a door to the basement. Hopefully on the next trip up I can get some trim installed. After that I really need to figure out what I want to do for a deck so that I can get a ledger installed and start shingling.
  • Senior Member
« Reply #185 on: March 23, 2021, 04:53:56 AM »
It looks great!
Offline pmichelsen
  • Senior Member
« Reply #186 on: March 24, 2021, 06:37:42 AM »
It looks great!
Thanks! It feels good knowing I have some fairly secure storage up there now.
Offline pmichelsen
  • Senior Member
« Reply #187 on: November 16, 2021, 05:05:11 AM »
My wife and I welcomed another baby girl over the summer and haven't been up to the property since June. We're heading up for Thanksgiving and I'm hoping to finally get the footings started up at the horseshoe pits for the shelter I've been working on for YEARS now. Ideally I'll get them laid out and dug, then during Christmas I can pour them. I also need to finish part of the cabin foundation that I didn't replace when I dug the basement. Fortunately I was able to salvage enough structural steel from a few jobs to cobble that together. Hopefully next summer when the girls are a bit older.
Offline jsahara24
  • Junior Member
  • Welcome to the CP-Forum
« Reply #188 on: November 19, 2021, 03:46:00 AM »
Congrats on the baby!  Kids certainly slow down the trips, but once they start getting older hopefully they will be asking you to go!
Offline NathanS
  • Senior Member
  • NY Mountains
« Reply #189 on: November 19, 2021, 06:58:01 AM »
Congrats! We've got another on the way, my building projects are all pretty much on hold now too.
Offline pmichelsen
  • Senior Member
« Reply #190 on: November 23, 2021, 01:59:25 PM »
Fortunately even at this age (our oldest is 3) our older daughter loves going to the cabin, as soon as she knows we're going she starts packing books and toys so that she's ready.
Offline pmichelsen
  • Senior Member
« Reply #191 on: December 28, 2021, 06:15:00 AM »
Our Thanksgiving trip up to the property ended up being a bust...
The wife and kids got up to the cabin around 4:30pm and while starting up the pellet stove my wife found that it gave up the ghost and was not working. Not what you want to see when it's 42 degrees inside and you have a three year old and four month old. She was able to get the propane wall furnace going but that takes a while to heat up the place, when I arrived around 10:00pm it was still in the mid 50's inside. The next morning the water system was out, one of my buddies was at the property earlier in the week so I knew there was an issue, but I had walked him through the repair over the phone.
Well I found other issues, I was able to get it to run but there was a slow leak on the inlet side of the pump so it would lose it's prime. Unfortunately I did not have the tools/materials needed to make the repair. So with that coupled with the fact that it was still only in the low 60's inside, we decided to head out the next morning.
We are headed up on Thursday evening, this time I'll have all of the parts and tools needed to get the water system back 100% and I'll also be bringing up a portable heater to help take the edge off the place. Still trying to decide what I want to replace the pellet stove with. At this point I'm leaning toward a freestanding propane stove.
Offline pmichelsen
  • Senior Member
« Reply #192 on: December 28, 2021, 06:28:01 AM »
I was supposed to have the basement at our main house finished out before number two arrived, unfortunately due to our architect and the city working at a snails pace it took 11 months to get our permits. So next month I'll be starting that project while trying to wrangle two kids. Not looking forward to it, hopefully grand parents will be able to help out, I'll be trying to do this over nights and weekends.
Offline pmichelsen
  • Senior Member
« Reply #193 on: January 03, 2022, 07:50:22 AM »
The water system is about 95% fixed, there is one dressler that I couldn’t quite get to seat properly, but I suspect is will close up on its own. I had forgotten it was even there until I started working, I also didn’t realize there was never a shut-off install on the outlet from the tank. With no shut-off it made my work a lot colder, as I was fighting back 4500 gallons of water while trying to get all of the connections to seal up. My goal was to add the piece of flex in line on the intake side, there is a decent amount of vibration with the pump and it had disfigured the sch 80 so it was sucking air.
I did verify that I have a sch 80 2” ball valve on hand, so over the summer (when it’s a bit warmer) I’ll dive into the tank and plug the outlet so that I can remove the piping, install a shut-off, and get rid of the dressler. I imagine there was a leak years ago and with no shut-off the dressler was the only option. Lots of band aid repairs over the years fixing the system “good enough”, it’s taken a while to find all of these are remove them.
But we did make it to the river every day to throw rocks and just be out in nature. I hope my kids take to the place the way I did, but I’m going to try to not force it on them. I introduced my daughter to sparklers on NYE and I shot off some pyro-gyros, they scared her a little bit.
All in all a good weekend, though it was 38 degrees in the cabin when we arrived.
The water system:
New flex installed ($220 in fitting right there):
The dresser that was giving me grief:
« Last Edit: January 10, 2022, 06:16:22 AM by pmichelsen »
