1\8 inch sheathing gap
Started by MarkAndDebbie, June 22, 2007, 08:51:36 AM
MarkAndDebbie
I know I am supposed to leave an 1\8 (or 16th dending on the direction? Wagner 111) inch gap between my sheathing. I asked some people how to do that and got several replies.
Someone said the OSB sold for sheathing is an 1/8th inch short. I believed this one until I put a tape on it just now.
Someone else said to put it up tight and then run a circular saw down the seam set at 7/16ths deep. This sounded like way more work than a normal framing crew would do. (I stopped by a new neighborhood to see if I could tell what they were doing, but I don't think I'll follow their example. Their gaps were more like an half an inch to an inch -yes that means that some of the OSB ran off the stud. But I'm sure it will be OK because it's not plumb - so some of every sheet seemed nailed in  :o )
Someone else said - you're not building a piano - don't worry.
What should I do? Won't I start to run off the stud if I am doing 8' + 1/16th for each sheet?
Thanks.
I know what it says - don't think I've been on a job where anyone worried about it.  PEG might. :)
youngins
On the playhouse floor sheathing, there was a natural 1/8" gap between the T&G once it all got tapped into place.
[highlight]I just touch the sheets together [/highlight], don't slamum uo "extra tight" make sure the ends are back a little 1/8 / 1/4 instead of hanging over a 1/16.
 If your going to be months before your in the dry , gapping might be a good idea , but if it's OSB and it swells no matter how much you gap it it well not be enought.
jb52761
I used those metal spacers designed for sheathing...I'm not worried about code here, not in city limits, but aren't those basically what folks use ?? They are about an inch and a half wide and just slip onto both edges, leaving the desired gap...boom, done.....jb
paul s
i wa s on a job recently antd the osb was 1/8" narrow.  we  used a nail on the top and bottom as a spacer  that was about 1/8 inch thick.
in fact wee had to take down 12 shees and put them back up  thankfully they were not anild but with a few nails with the plan to go back and nail over
i have seen rooofs buckle badly  so i always space them out as they say
Ok Stop are we talking wall sheathing or roof sheathing.
On walls butt it GENTLY together  no added force .
On roof with 24" OC truss's or rafter use 1 ea. "H" clip between each rafter, one per rafter bay, the end of the sheets again just touch together no added force , or gap them a little .
Some OSB,  I hear ,  is "down sized " but I never seen any . And I'll bet I've laid more sheets of CDX / OSB than anyone on this forum.
 Again YMMV .
  If your going to be a long time IE more than  month without a roof gapping may help some what , BUT when/ once  OSB swells it , never shrinks back any , it just gets thicker , and thicker .
Good luck PEG
MarkAndDebbie
QuoteOk Stop are we talking wall sheathing or roof sheathing.
Talking about walls (for now). I'll butt gently.
I'll use the clip, with plywood, and dry it in quickly :)
