Hey All,
This is my first post to the forum, but I thought people here might be interested in the little project I've got going - I'm building a green/natural and quite experimental little house to live in.
If you'd like to check it out, I'm posting photos and descriptions of the construction process online at: alittlehouse.blogspot.com (http://alittlehouse.blogspot.com/)
Enjoy!
-Matt
(https://i56.photobucket.com/albums/g166/jraabe/lh-2.jpg)
(https://i56.photobucket.com/albums/g166/jraabe/lh-1.jpg)
(PS - I copied a couple of images to Photobucket so they post here. JR)
That's cool!!!
Welcome Matt, not welcome mat. :-/ I mean we roll out the welcome mat for all new members. :)
Great little project there and I hope you don't mind but I edited your link so even Sassy could figure out how to get there. She's a bit computer challenged but is getting better. :)
Matt:
Interesting project and good use of SketchUp (http://sketchup.google.com/). I'm sure you have explored the tiny house ideas the forum came up with during the 200sf design contest (http://www.countryplans.com/contest.html). You are limited to 125sf so 75sf of "extra fat" have to be cut out of those 200sf mini-mansions! :D
I'm quite impressed with your plans & what you've done so far! Not too many persons at 22 y/o are thinking, planning & actually doing what you are doing... really enjoyed browsing through your blog once Glenn showed this "computer challenged" woman that I needed to put the link in the address bar (although MB25ACRES mentioned it)... I'm just so used to Googling & that's where I kept putting the address & Google couldn't find it :-/
(and to think that in the last position I was in at the hospital, administration sent me to a couple computer "camps" for a week at a time so that I could teach the others about the new programs... I was more computer literate than most of those I worked with :D )
Thanks for all the positive replys. I just posted a bunch of new photos of the progress on my site. Lets see if I can get the link right this time: http://alittlehouse.blogspot.com
Yeah, I did take a look at the 200sf design contest, and the main difference between my little place and the contest designs is that mine is 80sf smaller (120sf limit), but I also don't have kitchen/bathroom in it, so overall I'd imagine it will be about similar in terms of feel and cozyness, which for one person is just about right.
Again, thanks everyone for checking it out.
-Matt
Hmm. Dimples instead of barbed wire?
(between earthbag courses)
Yeah, I read about it online somewhere, and figured I'd give it a try. I wouldn't do it for a larger structure or one with more earthbags, but since I'm only running 2 courses of earthbags and every 2.5 feet I have a beefy #4 rebar stake through both courses, the rubble, and into the ground, I figured the barb wire was superfluous, and that I could afford to experiment.
-Matt
Probably right on both counts.
Just wondered if everyone had changed their minds about barbed wire or equivalent.
Ahoy,
Just thought I would post another message to say that I have recently put up a bunch more photos and descriptions of my little house project online. Check them out at alittlehouse.blogspot.com
Thanks for everyone's interest!
-Matt
Hello,
Been following your building blog.
The steel you used in the foundation to ward off termites - would it rust?
You indicated that you needed the building to be portable. How did you achieve this?
What are the dimensions of the structure?
I read something about sand traps for termites - anybody familiar with them?
I'd never heard of it. Found it mentioned here. "Not approved for use" doesn't tell us much. Anything from "you're dreaming" to "it would be a pain to train the poison-minded exterminators to do this":
http://insects.tamu.edu/extension/bulletins/l-1785.html
QuoteSand barriers are an alternative to chemicals. In some parts of the world, sand with certain size particles (1/16 inch) is used to physically block termite entry into structures. It is not approved for use in Texas. The technology requires considerable knowledge on the part of the applicator, and is generally unsuitable for use outdoors around the base of a foundation unless the sand barrier can be held in place.
The cutest--and least toxic--way to be repel termites is an "ant moat."
There's a--very--brief mention here:
http://www.howtogetridofstuff.com/pest-control/how-to-get-rid-of-ants/
But IIRC what someone posted to a probably no longer on a server list years go went something like--keep renewing a sugar solution around your house--possibly sand would be good. This attracts ants, who in turn see the termites as rivals (but the're not other ants!) and fight them off. She was an architect, but had mostly been working in New England, where termites are not the problem they are here.
I'd much rather have a house full of ants than a house full of termites. :-? :)
Yeah, termites are definitely a bummer. I have heard of sand barriers. As far as I understand the reason they work is that the termites can't build tunnels through the sand because the tunnels will collapse, and thus they won't be able to get through the sand to your house. As far as specifics of putting a sand barrier in, however, I'm clueless.
The metal I am using is galvanized, so it should resist rust. Also, it really shouldn't be getting that wet once the building is finished.
To answer youngins' other questions - I wouldn't really call the building portable; its more that its easily dissasembleable. I did this by making the walls in sections that are screwed together, and then using screws pretty much everywhere else (to attach rafters, siding, etc.). I think you could probably take the whole thing apart pretty easily if you had a week and a good screw gun. Also, you wouldn't damage any of the structure (except the foundation, which is permanent) by taking it apart - so in that sense you could probably take all the pieces and go reassemble it elsewhere on a new foundation, although reassembling it would take quite some time and effort.
Finally, the building is 10 feet by 12 feet.
QuoteI did this by making the walls in sections that are screwed together, and then using screws pretty much everywhere else (to attach rafters, siding, etc.).
The use of screws caught my eye... Maybe one of the members more well versed in construction can comment on this... I'm assuming we're talking about those bright shiny zinc plated deck type screws... is there a potential problem with them snapping under shear loads? I know when I'm tearing down something that was assembled with these screws they are easy to snap, whereas a common nail will bend. Or maybe if there are enough screws the loads are spread out enough to be okay.
I have built a number of structures meant to be disassembled if needed and have used bolts or lag screws to join members/panels.
One other personal observation... it always seems the screws went in a lot easier than they are to remove after they've been in place a year or so.
Screws can be a problem -- I've had wet wood shrink and pop the screws in half, and some uses of screws are not allowed by the building inspectors due to this problem.
I use them quite a bit myself but am aware of the problems they have.
Yeah, I too have had trouble with screws in the past, but I don't think that it will be a big problem in this structure. First off, the individual sections are all nailed together with 16d galvanized nails. Then, I used enough screws to attach the sections that I don't think there will be shearing problems. Finally, all my wood is salvage, which generally means it is old (somewhere between 20 and 110 years old) so it is quite dry. I've personally only seen shrinkage problems with new wood, especially the low quality stuff you can get at Home Desperate. Plus, the square drive screws drive much better, both in and out, as compared to regular phillips.
-Matt
PS. Working with 110-year-old 2x6 is pretty crazy. Its actually 2.25 x 6.25, with hard, tight, and straight grain. They just don't make wood like they used to.
I have 1931 bridge timbers - creosote treated - straighter and better than anything you will find today at Home Despot. :)
So, if you have to buy lumber retail, what are the decent buys ?
Buying retail you are stuck with about anything you can find. One dealer may be better than another but they are all stuck buying from younger trees which are not as good as the old growth.
People here can sometimes buy from any of several local sawmills. Not all of them saw on spec.
I guess it depends on where you are. Here the Home Depot stores have nice straight and mostly knot-free lumber.
Here in NM I have 2 HD to choose from (about equidistant) and a Lowe's a block away from one of them. Lumber quality is usually quite decent, tho' if the pile has been picked over it's sometimes hard to find a truly usable length until they bring down a new stack.
My bigest complaint is that it's more difficult today, than it was 10 years ago and longer back, to find good larger beams and timbers. There used to be a really good selection of locally, or regionally, owned lumberyards here (and everywhere else) that did most often have what I wanted. I miss those places. Of course it's not just the big box retailers fault; those big trees are harder to cut down these days, even they can be found. But if I really need an 8 x 8 or whatever big timber I can get it, just have to go farther away, into the lower rent industrial area, places never open in the evening or on a weekend, and pay more to boot.
On the plus side if you're looking for say, a new kitchen faucet, the HD's and Lowe's have more than you can shake a stick at. 'Course that complicates my life when DW can't decide what she wants (because of the too many to choose from). Don't really know if we're better off or not today.
Yeah, I used to think that lumber quality at HD was decent, but now that I've tried using salvaged lumber, I'll find it hard to go back. Even when you can get new lumber that is straight and fairly knot free, take one look at the grain and see how loose it is in comparison to older stuff and you'll realize the difference.
My unwillingness to go back to new lumber may be in part because there is a whole lumber yard that carries only salvage lumber just a 10 minute drive from where I am (driftwoodsalvage.com), so getting salvage lumber is really easy. If I lived somewhere where there wasn't a salvage lumber yard it might be easier to justify using new lumber...
You're a lucky guy Matt to have a good salvage yard so close. Nothing very great here except for sinks, fixtures, that sort of thing. :(
