Tree Stump Removal
Started by Redoverfarm, July 11, 2013, 07:17:47 AM
I had ran across this lately and thought some might be interested.  This is not the exact formula that I had seen before but maybe it is worth a try.  Most of the owner/builders do not have the resources for a mechanical means to extract stumps so this may be a good alternative.
Get rid of tree stumps by drilling holes in the stump and filling them with 100% Epsom salt. Follow with water, and wait. Live stumps may take as long as a month to decay, and start to decompose all by themselves.
interesting.  Any drawbacks?  Linkage?
I need to remove a LOT of stumps!
Quote from: OlJarhead on July 11, 2013, 10:23:23 AM
Don't know Eric.  Have never tried it.  I had once heard of similar approach but they used yogurt in the holes and something else but I can't recall what it was. ???
fishing_guy
Rob_O
Quote from: Redoverfarm on July 11, 2013, 07:17:47 AM
I always heard the best way to get rid of old stumps was to drill holes in them and fill the holes with gunpowder and det cord.  ??? Must be a KY thing
"Hey Y'all, watch this..."
firefox
Somehow I don't think KY jelly will work, even with a big winch.
Bruce
Bruce & Robbie
MVPA 23824
If KY Jelly wont work Bruce chances are that Vaseline................ ;)
firefox
Actually, I prefer the det cord idea. Stuff really works wonders.
Bruce
Bruce & Robbie
MVPA 23824
stricsm
If the stump is dry, drill holes with a large bit or hand auger to form a pocket in the center of the stump.  Use a charcoal chimney to start a load of charcoal.  Large stumps may need 2 or 3 loads.  Dump the charcoal in the pocket.  It will smolder for weeks.  This method will not only burn the stump but it may also burn most of the roots if dry enough.  I burned a 3' diameter Beech stump this way and it smoldered for about 3 weeks.  Smoke was coming out of the ground 10' away from the stump.  I got most of the roots on that one but it was a dry stump.
