I have put off starting this thread for awhile, but today seems like a good day to kick it off. A little less than 1 year ago, my wife and I purchased some property in the Michigan U.P. surrounded by the Ottawa National Forest. It's a pretty diverse 56 acres, some field, young forest, older growth, rolling hills, etc. It used to be an old homestead, and our plan is to bring some of that history back. Here are some pictures from winter and spring of 2012:
(https://lh6.googleusercontent.com/-hm-CYOA3tiA/T3kDwqxNyVI/AAAAAAAAAww/KykEujemQlU/s711/DSC00497.JPG)(https://lh3.googleusercontent.com/-7rB4_YpgtNQ/T3kC_6glzZI/AAAAAAAAAwE/c62maqkv5lQ/s711/DSC00439.JPG)
(https://lh4.googleusercontent.com/-Ue24sSsKixE/T3kDD0wWvrI/AAAAAAAAAwM/YfXoZ0u6LiQ/s711/DSC00441.JPG)
(https://lh3.googleusercontent.com/-_HK5vd9-aP0/T3kGez4VWWI/AAAAAAAAAzo/F3SMAApGhzc/s711/DSC00520.JPG)
(https://lh5.googleusercontent.com/-CQWp-Q1-09E/T3kGnWs9hfI/AAAAAAAAAzw/Tmu-JXdYq6M/s711/DSC00521.JPG)
(https://lh3.googleusercontent.com/-3dVDtYcsOns/T3kIUtRIYII/AAAAAAAAA1g/KOSxVEAQWFA/s533/DSC00538.JPG)(https://lh3.googleusercontent.com/-YqjNyMXyDIk/T3kJVcHdGbI/AAAAAAAAA2I/KaY5q0-rwb4/s533/DSC00543.JPG)
(https://lh3.googleusercontent.com/-y1Aam0QWOtM/T3kKeN0AsUI/AAAAAAAAA28/1ztJi-4cW34/s711/DSC00550.JPG)
(https://lh4.googleusercontent.com/-HGedug9BJlM/T3kLPfUst-I/AAAAAAAAA3g/2VhSVf3oYLE/s711/DSC00554.JPG)
The Building Site
(https://lh3.googleusercontent.com/-fI4kw8DFj74/T3kETsVqiII/AAAAAAAAAx4/Xngrkrf1NSo/s711/DSC00504.JPG)
(https://lh5.googleusercontent.com/-_ne1Tg-PMMo/T3kEKrhqpuI/AAAAAAAAAxo/V0WdT-4wjUU/s988/DSC00506.JPG)
(https://lh3.googleusercontent.com/-A-gHaKXW-lA/T3kLxPdEvpI/AAAAAAAAA4A/AcRSzfeL068/s711/DSC00557.JPG)
Some Artifacts
(https://lh6.googleusercontent.com/-gWrFzB7wDVg/T3kF1bwosgI/AAAAAAAAAzI/xAoI0wkBX8E/s533/DSC00516.JPG)
(https://lh4.googleusercontent.com/-_8hiyCgyslw/T3kGPIlxJdI/AAAAAAAAAzg/4XhRwqFkZDw/s711/DSC00519.JPG)
(https://lh5.googleusercontent.com/-Far6jRJcSzM/T3kH11wvvlI/AAAAAAAAA1I/NQVF4DrOmaA/s711/DSC00534.JPG)
(https://lh5.googleusercontent.com/-GcB7YwZMyRw/T3kHu7DvZ5I/AAAAAAAAA04/DbmXY44o9cE/s711/DSC00533.JPG)
(https://lh4.googleusercontent.com/-ztgGbkqddf4/T3kHvygmpzI/AAAAAAAAA1A/JT1XljO9wC8/s711/DSC00535.JPG)
(https://lh4.googleusercontent.com/-HQOQdctg1gc/T3kIHoYTyaI/AAAAAAAAA1Q/5tXS3kvPf8c/s711/DSC00536.JPG)
Trees have grown around this old well pump
(https://lh5.googleusercontent.com/-Eib9diTTeDk/T3kIMlvIqaI/AAAAAAAAA1Y/8UqhYUNZTDo/s711/DSC00537.JPG)
An Old Outhouse
(https://lh6.googleusercontent.com/-s0T-PgnaUB0/T3kGB5CIvAI/AAAAAAAAAzQ/jgCetDcM5yI/s711/DSC00518.JPG)
This website has inspired us this entire process, and we ended up purchasing a set of plans for the 20x30 1.5 Story with the intention of extending it to be 20x40, adding dormers, and a 30" knee wall on a full second floor. We also wanted a full length covered porch on 2 sides to enjoy the views that building on a hill allows. While sketching floor plans, we quickly discovered that adding 4' of width greatly increased the amount of space available to us. Using Chief Architect's Home Designer Suite 2012, we put together our plans.
The first floor layout. We wanted a very open concept with a very large kitchen. Not shown is the wood stove which will be to the left of the front door.
(https://lh5.googleusercontent.com/-G_rN9_pac4U/UPLf9CYufvI/AAAAAAAABL4/nUEeu_WDUwg/s774/1st+Floor.jpg)
Here is the second floor layout. The 30" kneewall allows us to squeeze a triangle tub into the place. As you can see, there are 4 very large dormers which really open everything up. The flat part of the ceiling will have a height of 9'. The wall separating the closets will be adjusted to accommodate the wood stove chimney.
(https://lh5.googleusercontent.com/-NULy2xLlZ4U/UPLf-O7ZOdI/AAAAAAAABMI/ClzxrI2-d8c/s715/2nd+Floor.jpg)
Eventually the basement will be finished, but here is the plan for initial construction. 4' of the basement will be below grade and made of poured concrete, while the top 4' will be conventionally framed and have large windows. This allows for egress and good ventilation.
(https://lh6.googleusercontent.com/-xgDoRopC3S8/UPLf9uAUj_I/AAAAAAAABMA/-fsOtIdvs84/s777/Basement.jpg)
Here are some pictures of the outside. It is a little deceiving in that it shows the basement walls to be fully concrete, and where the porch roof meets the main roof it's a little strange, but the intention is clear.
(https://lh3.googleusercontent.com/-xLvwnVSubxk/UPLf-6ZqpzI/AAAAAAAABMQ/9yeiyFYCU_c/s610/Front.jpg)(https://lh6.googleusercontent.com/-r2KfQL9uaDc/UPQ8hUHV4MI/AAAAAAAABNE/XkF54inI4Ck/s588/back.JPG)
I'll talk about construction for a bit. The wider 24' required some additional planning. I created a thread to discuss some of my planning. http://countryplans.com/smf/index.php?topic=12520.0 (http://countryplans.com/smf/index.php?topic=12520.0)
As you can see from my thread, I ended up opting for floor and roof trusses. Going through Menards, the cost was not much more, at least in my opinion, especially when one factors in the time saved in construction. Most importantly, this option allowed us to truly have whatever floor plan we wanted without the need for supporting posts and interior bearing walls, excluding 1 post in the stairway. There are other advantages with trusses as well, running mechanicals and plumbing without intrusion being a big one.
Once we finalized the plan, we started the construction loan process. While I am pretty handy, my job capitalizes a great deal of my time, so we decided that paying for labor to build the shell would be best. I was my own "General" and pulled all permits, so while there was a certain amount of cost involved, this helped lower the labor cost some. We were referred to a contractor out of Wisconsin, who was very reasonably priced. He showed me a garage he built, and the work was top notch. He was very friendly and seemed like a stand up guy. It was late fall at this time, and we were in a rush to beat frost, so we put money down to pay for the concrete work-Poured walls, insulated slab with pex, and sonotubes for the porch. He broke ground in late November, this is where things started to go wrong.
If I'm perfectly honest, this is why I have waited so long to post this project. I am a bit embarrassed by the fact that we were taken. I should have known in the beginning, when he mentioned his business was run through his sister, as he was in an accident and was collecting disability. People go through hard times, and I have many "planks in my eye" so looked the other way. To tell the truth, it isn't something I am proud of.
I also should have known when he called saying he had to do a bunch of extra site work, and wanted extra money, but it seemed reasonable as he did improve the driveway which was needed considering the huge amount of rain we received. We negotiated a price for the work, the footings were poured and inspected, and my wife and I went on vacation. He sent a few pictures which were very encouraging.
(https://lh4.googleusercontent.com/-agiKFNoLny8/UMuI66SEtfI/AAAAAAAABGw/jqVjxktwQpY/s711/2012111095142319.jpg)
(https://lh3.googleusercontent.com/-kvxex4RTSdA/UMuI7AJ6wWI/AAAAAAAABG4/BmHoU6ZUXTA/s711/2012111295141656.jpg)
(https://lh6.googleusercontent.com/-T52PtllvfRM/UMuI7FB5cqI/AAAAAAAABG0/QmI-PkzamPg/s711/2012111295141717.jpg)
(https://lh4.googleusercontent.com/-ZEMsxTIbU1s/UMuI8l4RQzI/AAAAAAAABHI/dseQr26zsz8/s711/2012120695102730.jpg)
(https://lh6.googleusercontent.com/-CkcPB80_hrI/UMuI9udJ56I/AAAAAAAABHQ/lMsNuPEtFbE/s533/2012120695102813.jpg)
(https://lh4.googleusercontent.com/-rYKWhV89yDo/UMuI95DoUrI/AAAAAAAABHY/FmVATVsLFNY/s711/2012120695103044.jpg)
Things are looking pretty good at this stage. The walls were tarred, installation installed, and drain tile was inspected and approved. I drove up to see how things were going, and took some more pictures.
(https://lh6.googleusercontent.com/-vt9KqD_03AQ/UN6Nls08O-I/AAAAAAAABIs/xw4PNwvkno8/s711/DSC00984.JPG)
(https://lh5.googleusercontent.com/-SDhsE6ZKBmM/UN6NlS_gFsI/AAAAAAAABIo/rZhR-OB5Zzw/s711/DSC00985.JPG)
(https://lh3.googleusercontent.com/-HsRdU3SHC2M/UN6N2H7nbrI/AAAAAAAABJA/rRaCDXLkgtE/s711/DSC00987.JPG)
(https://lh3.googleusercontent.com/-HypyEsyZb8c/UN6N2Rci8FI/AAAAAAAABJI/b6FdVSc2IMI/s711/DSC00989.JPG)
One reason why I didn't fight him too much on the extra cost, was the fact that unlike the rest of the area, the hill we built on was not made of sand, but heavier "waste" fill. We weren't aware that many years ago, the previous owner had sold the sand to the county for road construction, and waste material was brought in. This made digging harder, and also meant that what was removed for the foundation wouldn't be the best used as backfill. I had a sand/gravel mix brought in, and the contractor back-filled the foundation. Keep in mind, and it is hard to see in the previous pictures, but I never saw what the walls themselves looked like. The forms were still on the inside, and insulation was on the outside.
The contractor was not very good at communicating with me, which I attributed to the remote location and no cell service, so I decided I should check out the site to see where things are at. I came up and found this.
(https://lh5.googleusercontent.com/-w426DYz_zjU/UQGbEzHnk_I/AAAAAAAABNs/LvVQLdqgGxY/s711/DSC00993.JPG)
(https://lh5.googleusercontent.com/-qjmsdSP5Azo/UQGbNQDR0vI/AAAAAAAABN0/W_knQO5B-pM/s711/DSC00994.JPG)
(https://lh3.googleusercontent.com/-ky2fd807Tgk/UQGbVkb6MII/AAAAAAAABN8/SvtopcWQnB4/s711/DSC00995.JPG)
(https://lh4.googleusercontent.com/-0f1YDb4gV40/UQGbYhz_TBI/AAAAAAAABOE/6crcGDt_poQ/s711/DSC00996.JPG)
Rock pockets, pour lines, bad ones. This is what happens when winter mix is setting just a little too quickly, and a concrete vibrator is not used. The contractor was not onsite, so I tried to call him immediately. I left some frantic messages. No call back. As I mentioned he hadn't been communicating, and we were starting to worry. I called a general contractor friend who had referred me to him, and he graciously invited me over so he could see the pictures. We ended up going for a ride to visit his go-to concrete guy.
This concrete contractor is a true professional, and actually poured the slab on our addition to home in Lakewood. Great work. The only reason we didn't go with him was because we wanted the main builder to be responsible for what he was going to have to frame on. One less question mark for the rough in so to speak. He reviewed the pictures I posted here showing the rock pockets, and decided that it would be best to have his wall expert check out the site. The next day we drove up with him, to determine what we were dealing with.
The verdict was both good and bad. It was the worst wall he had ever seen. Truly an ugly specimen. Fortunately for us, ugly was the main issue. Structurally, the wall was just fine. Our biggest concern would be water infiltration in the future should the grade be wrong and tar wear out. He suggested I get some money back should I have water issues in the future. We decided that $3000 seemed like a fair amount, but also that I would be well within my rights to request a tear down and redo. He also noticed that the footings had no insulation on the inside, and that straw needed to go down right away to prevent shifting. All of this advise, and the guy didn't want a dime for his time. I said this was unacceptable, and after some negotiation, a 24 pack was the agreed upon fee.
Another frantic message caused the original contractors girlfriend to call. Apparently he was sick, and the next day they would be sending someone to put down straw. Later that week, I laid out the options for the contractor.
1. Tear out and start over-the default option should he not like 2 or 3.
2. Remove the backfill and insulation, and have a rubberized coating sprayed on the wall.
3. Give me a 3K discount on the framing cost should there be a future problem.
He reluctantly agreed to option 3.
Was there an old house site at one time or was it just a country dump for a nearby farm. I see the remains of an old wood cook stove w/ water jacket. The water jacket is usually made of copper. If there was an old site there have you found any evidence of a well?
Looks like a pretty nice piece of land offering a little of everything.
After that, the contractor was on thin ice. Very thin-so when he wasn't getting back to Menards regarding truss setback questions, I had it out with him. I was on the phone with him on the way to his house to get my money back. After expressing my frustration and calming down a bit during the conversation, he agreed he would communicate better. His framing/siding/roofing work was very good after all, which can be hard to find.
He improved significantly for about a week, and while he did approve the wrong set of floor truss specs, it was partially my fault so I let it slide. You know, telling this story has made me realize I need a little more skepticism in my life. In any event, all specs were hammered out and approved, and delivery was set. We left a message with the contractor telling him when supplies were set to arrive. Then I left another message. Then another. Then I received an email requesting that we delay the delivery, as he was injured. I called him, expressing concern as to the timeline, and he said he would call me back after his doctors appointment, and he thought he would be back to work very soon. He never called. We were done.
Not wanting to speak to him for fear of saying something I might regret, my wife called. We were to get our money back, all of it, immediately. On the way to get my check, I got a frantic call from him saying he didn't have it. After some exchanges and talks of collateral, as in him not having any, I told him if he didn't give me a promissory note from the business to repay the full amount, a deputy would be picking him up. He gave me a note, and I told him that neither he, nor anyone associated with him was to go to the property for any reason, and the camper was to stay until I was paid, even if it belonged to his girlfriend.
Why was I satisfied with a promissory note? I mentioned it earlier, but the business belongs to his sister, and while he may be a dead beat, she is a teacher in Illinois. This means that there is at least some chance at seeing a return of my monies. My wife and her had a very loud discussion, but she said that if we provided her with a copy of the note, she would repay. I don't think she believed we had one-but she has 2 copies on the way to her home-(1 certified, 1 not in case she is not there) and another certified copy on its way to the school she works at, as the secretary can certify it was delivered.
We spoke with the sister again later, where she confirmed the existence of the promissory note, but now she had concerns about her ability to pay it back. I don't believe it for one second, as she owns a second home on a lake that the deadbeats live in, her wages can be garnished, and I suspect pensions can be cashed in. In any event, that promissory note is going to make court a walk in the park, which is where we likely will end up, as it removes the need for me to prove their screw up.
One last thing to mention about the dead beats. You know that high quality work he showed me? As it turns out, it wasn't his. Another guy did the work. This is why, if we go to court, we will be seeking punitive damages for fraud. To backup this fact, the disability fraud will also be part of the case, and should the sister be unwilling to pay us back, a letter to the school board will be drafted explaining how she is helping commit this fraud.
I apologize for the novel, but I thought some might find this interesting, and that others might learn from my mistakes. I know I am wiser for it.
Let's move onto happier times. A new, very VERY reputable contractor was found, and while he costs a little more, I will sleep much better at night.
This was the building site as of yesterday afternoon!
(https://lh4.googleusercontent.com/-FNV-NaSa2xE/UQGbfHI99RI/AAAAAAAABOM/I8FnvK77rpU/s711/DSC01007.JPG)
(https://lh3.googleusercontent.com/-MaLYOorARPs/UQGboaI3jGI/AAAAAAAABOc/MA--Ay4Z8DY/s711/DSC01009.JPG)
(https://lh4.googleusercontent.com/-lfYL3QbiEXI/UQGbvKE96SI/AAAAAAAABOk/GzXGRx6E-vo/s711/DSC01010.JPG)
(https://lh4.googleusercontent.com/-JZHbWO4c_zg/UQGbxJWVhHI/AAAAAAAABOs/9sHX6ieJPhg/s711/DSC01011.JPG)
Framing started today!!!
Quote from: Redoverfarm on January 24, 2013, 05:58:53 PM
Only one storage shed remains, and that is on the neighbors property. From what I was told, there were a couple of home sites. One was in the field, and the foundation was likely removed with the sand. The other was back in the woods near the outhouse, though I have yet to find the foundation. There is, what appears to be, a hand dug well near the pump, though it is filled in with leaves and other debris.
One interesting find not pictured is a very large lightning arrestor. It is as big as two or three 55 gallon drums stacked, but is made of 1/4" steel. I have a picture of the tag on it somewhere. I suspect it was filled with some kind of fluid.
Thanks!
Quote from: mgramann on January 24, 2013, 07:10:09 PM
Thanks!
It's good that you know the location to prevent someone from falling in. As far as contractors go it seems for every good one there is 5 bad ones in the mix. Hopefully this one will get the job done without all the aggrevation.
Thanks for sharing the pain. I'm often just as encouraging to hear how others have pushed through difficulty as to hear about their success. (Although I do hope the rest of the build goes a little bit smoother for you guys.)
Thanks for sharing your project and your frustrations. You have worked up an fine project there and things will probably be humming along soon. Going with web trusses and engineered joists make good sense when you want wider spans on the building width.
Absolutely gorgous property!
Weren't you just building in WI, or am I crazy? I have looked at this forum and read things for years and just now getting to point of joining and hopefully building next summer or fall.
Michigan (UP especially) has some beautiful spots and some of the best value for buck in upper midwest I suspect
Thanks!
Believe it or not it's been about 2 years since we did our bedroom addition in Wisconsin! For those who haven't seen it, here is the link(http://countryplans.com/smf/index.php?topic=11579.0 (http://countryplans.com/smf/index.php?topic=11579.0))
I live there pretty much full time, with my wife commuting to S.E. Wisconsin for 3 days a week. Last year, I was able to negotiate full time work from home privileges, so anywhere I have an internet connection, I can work from. Our lot in Wisconsin is pretty small, only about 1.39 acres, which isn't really conducive to the homesteading projects we would like to start.
Land it the U.P. is pretty cheap. I would guess we paid about 1100/acre, though we did get a very good deal in that we paid under appraised value.
On another note, the owner for the business that took our money made it clear that the only way we will be repaid is if we sue them. My guess is they have some kind of insurance that would cover a judgement against them. We really tried to work with them, but they wouldn't budge. Now, should we win, they will have our legal fees to contend with, and, should we choose to go that route, punitive damages. What a bunch of scammers...
I have been through these issues before during a rennovation in Maryland. I cant tell you the things I learned. I hope it goes better for you. WE will be looking at a property on the the UP in the spring that will be outside of Paradise, MI. My spouses parents are from MI so we thought it was natural to build there. I would like to know who your contractor is so we can get some ideas on code etc. WE are looking at the Victoria cottage on a tall pier foundation. I am curious about your experiences there, I am truely sorry you were taken. I makes some of the process bitter sweet. My ex brother in law did the same to me. Windows leaking etc. At least you aren't related to this loser. It was an eye opener. That I think is why we want the contractor to build the exterior pour the piers and pull the plumbing/electric and thats it. My father and Brother in laws can finish the rest so we can save money too. I tell you stay on top of even a good contractor they will cut corners too.
The easy money flowing in the 2000's brought many an unskilled or underskilled rummy into the building trades to get their piece of the pie. After a 5 year dry spell, they are desperate even to the extent of ripping off family members. Often the law is no recourse since they have already bankrupted a business entity or two and won't hesitate to close down another.
Once someone learns to walkaway from debt or liabiliity via bankruptcy, just like insurance settlements, the liklihood increases greatly in the future. As the old saying went: "There is only one way to cure an egg-sucking dog".
I don't think one can apply excessive due diligence in screening right now.
One thing about DIY, I may not match the skill of others, BUT, I DO have my best interests at heart!
Quote from: bayview on January 30, 2013, 11:49:06 AM
I'm sorry to hear about all the problems that you have experienced with the builder. . . It shows that you need to be right on top of things 24/7
I would be concerned about the concrete-foundation. It seems to me that water infiltration during the winter would freeze . . . Leaving you with major problems. There was not any adhesion between pours . . The rock pockets and pour lines. Seems like a potentially weak wall.
Two separate contractors both agree that while ugly, it is structurally sound and the adhesion was adequate. Being that the wall is insulated from the outside, the concrete itself is in a conditioned space, meaning it isn't subject to freezing. Keep in mind it is an 8" solid wall, and I would suspect it is at least as strong as a cinder block wall which is thinner, and is porous.
Quote from: bayview on January 30, 2013, 11:49:06 AMI'm sorry to tell you that I think your money is long gone, even after suing . . . They have no money and nothing for you to put a lien against. (Personal experience)
Good Luck with the rest of the build.
I disagree. The business seems to be a DBA, and she is a teacher for an Illinois school district. Pensions and personal property are all fair game since the business isn't separate from her personally. Wages can be garnished, her vacation home seized, etc. If it were a Corp or LLC, the business stands alone, but as a DBA, it is literally just herself personally operating under a business name.
Quote from: bayview on January 30, 2013, 02:34:22 PM
Again . . . I hope it works out. I didn't mean any disrespect . . .
Did you have a contract with the business, the sister, or were you working directly with the deadbeat? A written contract with the business name?
I wonder if the sister knows about the possible legal action . . . Maybe have a lawyer send a "demand" letter.
For what it is worth. . . I never give a contractor-builder any money up front. Generally I would pay the contractor in installments as the work was completed. A contractor I had previously dealt with was requesting money up front for "expenses and supplies". I told him to order the supplies and then I paid the lumber yard myself. I found paying for materials myself eliminates any possible liens from vendors that weren't paid by the contractor.
No worries Bayview.
The contract is with the business, with the check made out to the business. The promissory note also lists the business as paying us back.
The sister is the one that said we need to sue. She fully admits they are liable for it, she just has no intention of paying.
I really wish we hadn't given the money up front. We were in a hurry to beat the frost, and didn't want any hang ups. It's a mistake I won't make again.
Not sure how things can be done in Michigan but in Minnesota they have small claims/concilliation court that can address up to $7500 - maybe its now been changed to $10k at that.
Pretty simple process and its been used to clean the dirty contractors out to some extent. When a judgement is entered its a matter of having a sheriff serve the employers to enforce garnishment.
The losing party CAN take it to District Court on appeal but thats almost a simple pro se matter as one already won once. Let the loser waste more money if he/she chooses. They rarely get reversed.
And yeah - I know first hand how the whole stinking thing works only to well. Been in your shoes twice. A PITA but a few hours time and I was made whole legally.
I think most of the garbage folk been run out but there are always these leeches hiding.
Sorry to hear this - and hope you have easy route to "get 'em" as they have it coming.
Good luck
I too hope it gets resolved. I could have been there too. we had a roofer put the roof on but before he tried to do that he wanted money. I paid everyone as work was completed. I bought materials and delivered them to the work site. I saved me money and the contractor couldnt jack up the materials costs.
I can see where a contractor also wants money at signiong, on delivery and balance on completion.
I have several friends who are or were GC's and also way to common story to have the HO's stiff them on back end pmts. They usually have a pre-lien notice in contract but what good is a lien in many cases when the HO is upside down and could care less. This is especially an issue in insurance claim work. Then the HO gets it done and atually pockets $$$$
crazy world
QuoteTo me insurance claims are just about always a "scam".
I don't follow what you mean. ??? We had a water damage claim a few years back. The insurance company gave us a check. It was a fair amount in our judgement. They had nothing to do with the repair work materials or contractor selection. We did some work ourselves. We bought the new floor tile ourselves and found a contractor to do the tile installation and grout. Everyone was happy; us especially. Maybe I just don't understand your perception. Careful shopping on our part, plus the DIY labor, left money from the insurance company to pay for most of the replumbing which was not covered under the policy.
QuoteDid an insurance agent come out to your home, do an inspection, and then cut you a check?
Quote. . . How does the insurance company know that the work was completed, completed properly, and to quality standards? Did the insurance company do an inspection when the work was completed?
My point was that here in NM at least, it seems that all the insurance companies do is assess the claim and issue a check to the homeowner / policy owner. Over the 28 years living here we have had two claims, one on a rental we own and one on our home. In each case they sent out an adjuster and they assessed the damage. They wrote a check on the spot. In the case of the rental unit I did not think it far and after a couple weeks of wrangling, after I sought independent estimates, they took that check back and issued one in a higher amount. That was it. They never asked for any proof work was performed. With the water damage here at home it was similar, except they offered more money than we expected. I knew what it had cost to do originally and had a good idea of the replacement costs. So when they gave us the check, we spent a couple days verifying the replacement estimates, then cashed the check and started repairs. Again, that was it as far as the insurance company. Never saw them or heard a thing until the next renewal when the rate increased slightly; under 5% IIRC.
Having the work done properly??? I guess the same "rules" that apply to every other aspect of repairs and remodeling, contractor selection are in play... you have to look out for yourself and choose carefully. My responsibility, nobody else's. That is unless a service that requires an inspection is performed. The re-plumb portion was permitted by the contractor and inspected by the local city inspector who actually did crawl into the attic and go from one end to the other as well as look at all the in wall connections for the supply lines. In August heat.
Does this procedure of estimate and check writing vary state to state? I have not had any experiences anywhere else with homeowner insurance claims. Lucky I guess.
Myself, I don't think I would ever use a contractor who rang the door bell on speculation.
Time for an update! I finally took a vacation day Friday. The plan was to dig a trench to install a continuous footing and sonotubes for the porch, but the frost beat the backhoe. After two broken teeth, we decided it would be best to wait until things thaw. The trip wasn't a complete waste-I got some pictures! I'm really excited to get working on MY portion of this build!
A view from a distance.
(https://lh3.googleusercontent.com/-Vkd6-JPSBrk/URgH_WqIAzI/AAAAAAAABPY/DEpSmAGZBx4/s711/DSC01017.JPG)
From the base of the hill.
(https://lh4.googleusercontent.com/-aAqw3_dGsvo/URgILmC4fvI/AAAAAAAABPg/dGkxtrKE2iQ/s711/DSC01018.JPG)
The sky-trak...quite a machine.
(https://lh5.googleusercontent.com/-Mj8cne3ckt4/URgIVG0JyrI/AAAAAAAABPw/kH0JogMIZoI/s533/DSC01019.JPG)
(https://lh4.googleusercontent.com/-T4FkFaFVE3U/URgIQ1TPV1I/AAAAAAAABPo/2o432sF5yGQ/s711/DSC01020.JPG)
The front.
(https://lh5.googleusercontent.com/-nfyxNnIX_Dc/URgIeTsSF0I/AAAAAAAABP4/fQSNOOCaVxg/s711/DSC01021.JPG)
East side. There are 2 windows on the lower level that are currently covered by OSB.
(https://lh6.googleusercontent.com/-fEJfYLzBzsc/URgIhzz3TRI/AAAAAAAABQA/9JyE9QAkFuc/s533/DSC01022.JPG)
South side. The window height on the dormers is going to be adjusted.
(https://lh4.googleusercontent.com/-vfvSWqtB55g/URgIiZgJb4I/AAAAAAAABQI/xNUeREeTgNI/s711/DSC01023.JPG)
The basement-still full of snow.
(https://lh6.googleusercontent.com/-VBKWvvwyP2A/URgIr1eVg1I/AAAAAAAABQQ/s7qC8bUvqQM/s711/DSC01024.JPG)(https://lh6.googleusercontent.com/-qOcJ5l9cDvg/URgItTEvngI/AAAAAAAABQY/40MouO1z1nI/s711/DSC01025.JPG)
The west side.
(https://lh6.googleusercontent.com/-S_GFzqmvyhU/URgI8l3kG3I/AAAAAAAABQw/chCz6zVJre4/s533/DSC01027.JPG)(https://lh6.googleusercontent.com/-VLahhpQuMdA/URgJNT2ZSxI/AAAAAAAABRI/dkwMnjT7yPg/s533/DSC01029.JPG)
1st floor looking west.
(https://lh4.googleusercontent.com/-uBcOWhFYEwE/URgJM0FvBwI/AAAAAAAABQ8/5Yn1FxmmUtM/s711/DSC01030.JPG)
1st floor bath, stairwell.
(https://lh6.googleusercontent.com/-HHzeSeeaP38/URgJMm7qTRI/AAAAAAAABQ4/tqei-WpjExg/s711/DSC01031.JPG)
1st floor looking east.
(https://lh3.googleusercontent.com/-L9OGb3TbUZ4/URgJecHYvFI/AAAAAAAABRQ/oLstofvzLyw/s711/DSC01032.JPG)
1st floor view out northern window.
(https://lh5.googleusercontent.com/-BuTndcYEc40/URgJgOhzAHI/AAAAAAAABRY/HdeK7rLso1A/s711/DSC01033.JPG)
2nd floor master bedroom, northern view.
(https://lh5.googleusercontent.com/-fBLrGmhHVzw/URgJwp6hcMI/AAAAAAAABRg/DAaLesxVQGI/s711/DSC01035.JPG)(https://lh4.googleusercontent.com/-zF3Hyo9YOE8/URgJzx-zrEI/AAAAAAAABRo/KO9UmR-h_EY/s711/DSC01036.JPG)
Other pictures of 2nd floor.
(https://lh3.googleusercontent.com/-vBmleTBlZq8/URgKFfkcygI/AAAAAAAABRw/fxsWICDBloU/s711/DSC01037.JPG)(https://lh4.googleusercontent.com/-YwuNPx8h9So/URgKMd_NZ4I/AAAAAAAABR4/hzPdn9iZtoI/s711/DSC01038.JPG)(https://lh4.googleusercontent.com/-qzsti40kecU/URgKY4MbSJI/AAAAAAAABSI/o3KnAutoR_Q/s711/DSC01040.JPG)
A little gift to help the workers to enjoy their weekend.
(https://lh4.googleusercontent.com/-QBAh_7Dvc6E/URgI6bQRg6I/AAAAAAAABQg/2K9QLUdwvi8/s711/DSC01028.JPG)
Quote #1:
Quote from: mgramann on January 24, 2013, 06:59:41 PM
Quote #2:
Quote from: mgramann on February 10, 2013, 10:35:21 PM
Time for an update!
I count 17 days between these posts. I think it is going to take me a whole lot more than 17 days for similar progress on my much smaller cabin. :)
The crew worked very quickly for sure. When I start working on it, things will slow down significantly, as I'll be limited to weekends.
I was able to visit today to get some update pictures.
(https://lh4.googleusercontent.com/-1vowKFDeeBk/USAH0fbHVqI/AAAAAAAABVA/NogsB4i4qeA/s533/DSC01045.JPG)(https://lh3.googleusercontent.com/-FApavS1cVxI/USAHz9TUysI/AAAAAAAABU4/tIfzDkkthbY/s533/DSC01046.JPG)
(https://lh5.googleusercontent.com/-pWrBP1QqNt4/USAIFUiC5mI/AAAAAAAABVQ/DmoAzqlQsQE/s711/DSC01048.JPG)
(https://lh6.googleusercontent.com/-Lrw9FPbjsVc/USAIGZN3CEI/AAAAAAAABVY/GCPR14-qtls/s711/DSC01049.JPG)
(https://lh6.googleusercontent.com/-wogh1mSlSbs/USAIXVRfgDI/AAAAAAAABV4/rfYIyWzcidY/s711/DSC01051.JPG)
(https://lh4.googleusercontent.com/-oyeq6b0E_bU/USAIV5_7wRI/AAAAAAAABVw/6Uw3htq1vf0/s711/DSC01052.JPG)
(https://lh3.googleusercontent.com/-wt8p_GD3lwk/USAIkOP1K_I/AAAAAAAABWI/abY4-AIMWLg/s711/DSC01054.JPG)
(https://lh4.googleusercontent.com/-EZQtStoID1k/USAI0YkNrtI/AAAAAAAABWY/21JhqPGX3y8/s711/DSC01055.JPG)
(https://lh5.googleusercontent.com/-W91ec-j7yrs/USAItFtzZmI/AAAAAAAABWQ/mkz8m2I_HRI/s711/DSC01056.JPG)
(https://lh6.googleusercontent.com/-26O9igcAd0s/USAI9GrQkkI/AAAAAAAABWg/1ncd2CTWygk/s711/DSC01057.JPG)
(https://lh6.googleusercontent.com/-N6hWX0g4veg/USAJEejfc7I/AAAAAAAABWw/7B9Uh-HGUrY/s711/DSC01059.JPG)
(https://lh6.googleusercontent.com/-fUZ8jMWR4Z4/USAJPQCvf8I/AAAAAAAABW4/tjY_mFUX278/s711/DSC01061.JPG)
(https://lh3.googleusercontent.com/-SrdlovIbPZg/USAJUgn_eyI/AAAAAAAABXA/OS_LjrBtcS0/s711/DSC01062.JPG)
(https://lh5.googleusercontent.com/-7P12r4U_1iE/USAJlf9m5oI/AAAAAAAABXY/eaDm1MhyXwo/s711/DSC01064.JPG)
The 9ft ceilings really open things up.
(https://lh6.googleusercontent.com/-zN__6wMeAWQ/USAJ-NQ4BGI/AAAAAAAABX4/1uT8YnSCVQo/s711/DSC01065.JPG)
Some more views
(https://lh3.googleusercontent.com/-Zhal5N2MNVk/USAKWqN_iEI/AAAAAAAABYg/e73JREl9H-Y/s711/DSC01076.JPG)
(https://lh3.googleusercontent.com/-SMGCXEsTFWg/USAKjQhYIcI/AAAAAAAABY4/aPh0bGs6BNY/s711/DSC01080.JPG)
(https://lh5.googleusercontent.com/-LFY3leKTsJg/USAKrhvNcLI/AAAAAAAABZI/FNaNMuwyP0w/s711/DSC01081.JPG)
I had a little fun with the lift today. I have some video, but I can't link directly with Picasa.
(https://lh5.googleusercontent.com/-f5j_xed8I80/USAKQpUtl4I/AAAAAAAABYY/ZThEtIcIcyk/s711/DSC01072.JPG)
One of my best employees
(https://lh6.googleusercontent.com/-jUxzxzcNUds/USAKLApAUuI/AAAAAAAABYQ/obcu7Cup1P4/s711/DSC01071.JPG)
The roofing and siding will start on Monday. They will do everything they can without the porch.
I am looking to build on the UP in Paradise Mi. Where are you located? We will need someone to frame our cabin, put in the windows, doors and roofing for us so, we wanted to know who you got to do it? The work looks really nice and I think it has come a long way from what you had in the begining. We live in Delaware but his family is in MI on the LP and south. We would need to get some one to do just those things and then we can do the rest. It just comes down to time is all. He is retired AF but I am still working. I can only get two weeks off in the fall every year. He and my dad are going to do alot of the finish stuff including building a wrought iron spiral stair case. Da was a millwright and master welder but he is in his seventies and his eye sight isnt good enough to do it all even with my spouse helping him. we will provide all the materials but we need good labour. As you know from your experience that is a must. If any one can help please let us know. Thanks.
Hi Ponygirl! I am south of Kenton. I'll shoot you a P.M. with the other information.
Cool. How far is that from Paradise? We are looking at ten acres of land there from North coast Realty. I can't touch land like that for the cost in Delaware. We wanted to know about inspections, permits and the like on The UP. We are happy to be secluded. The end result with be a reverse bird situation for retirement. Here in the hardest part of winter and there in the spring through the early fall. We like do it yourself but time restrains me. He is free being retired and all but Im not, plus I am full time school. This would be our retirement home. Thank you for getting back.
We are about 200 miles west of you. The land prices in the U.P. are great. Inspections and permits are a pain in themselves, but most of the people we have worked with have been very friendly and helpful.
I don't know that I could ever be a snowbird. I love the northwoods in winter too much.
I grew up in the snow in PA but I have arthrytis in my back and hip so I can't do really bad cold for too long. Bradley has suffered from combat related injuries so we are looking for quiet and piece of mind in the north woods. I love snow too. Delaware is so wet though, mostly rain along the shore. Permits a pain? How so? we are looking to do an enclosed Pier foundation with rebar and a skirting along the piers to enclose the underside of the house. We will do r30in the floor and a belly wrap to enclose the insulation. We are going to build the little house modification and add two wings one on each side.
A big thank you to Bradley for his service, and to you for the sacrifice you made as a spouse.
The permits were a pain in that I considered them tedious and expensive-though I admit I have a natural aversion to any procedure or cost associated with getting permission to build on something I own. I suppose deep down I do understand it isn't entirely without value or merit. The key is to be really organized, and have spare copies of everything.
After speaking with several local contractors, I don't know that I would do a pier foundation in that region. Frost has nasty habit of lifting them if the conditions are even a little less than ideal. This is why for my porch, I will be using a continuous footing below the frost line to tie the piers together and to help combat lifting. Another option is what is called a "big foot" footing form, where the sonotube is placed on a form that flares below grade. For me, since the trench is going to be there, I may as well link all of the tubes together with the footing. Even doing things this way, the porch relies on being attached to the house for lateral strength, since it has a full foundation.
I would really consider a perimeter wall foundation. I don't know that the cost will be that much greater.
I created a thread discussing the footing/sonotube combination. I'll try to find it and link it up.
Edit: Here is that link http://countryplans.com/smf/index.php?topic=12830.0 (http://countryplans.com/smf/index.php?topic=12830.0)
While the builders have been hard at work, so have I, albeit to a lesser extent. Here is a picture of the hydronic system I designed and assembled to serve as the primary furnace in my soon to be home.
It is a 6 zone system heated with a propane-on demand water heater. I still have to wire up the heater control and install the gauges. In-floor heat is truly a wonderful thing.
(https://lh4.googleusercontent.com/-Fc4GD8PaOb4/USPrQ2OQXpI/AAAAAAAABa0/T8QYSfxrC7U/s692/DSC01084.JPG)
Please ignore the galvanized piping, it was used for "mock up" purposes only, and will be replaced with regular gas piping.
I researched this at length. My neigbor is a retired seabee and contractor out of Pittsburg, PA. He said the piers should be reinforced with rebar and they should have a footer at the bottom of the peirs. The footer shoud be below the frost line. The rebar has the same expansion rate as the concrete so it helps with the lifting issue. The peirs are not connected in a trench but are done one at a time. Most likely they will be total length of 48 inches including what is under ground plus the footer should be another four inches. The object being to give a crawl space of 36 inches. Add floor joists of 2x12 and the floor is well above the ground. We should get that 36 inch space. The taller joists will allow for better insulation of the floor. The foundation you are talking about will push our costs up too high. Peirs should cost about 1200.00 instead of about 3-4k. We are on a budget and paying cash. Brad will be told you thank him. I was not with him when he served I just got to clean up the mess after his ex took everything kids included and left him alone and starving in his house. She is still trying to take the house...and his retirement. This cabin is so he can feel like he has something we own ourselves to celebrate his life and service. Our cabin when the shell is built should cost about 30k. If I only get the roof and sheeting done so be it. We can take it from there. We need to be frugal in our plan. habitat restores are excellent places to buy building amterials. I would purchase as much as I can in Delaware because there is no sales tax.
A good weekend at the building site. Some of the roofing has started, along with the siding. My wife and I were able to assemble the woodstove and most of the chimney. We decided to move it from the original location so it would be more centered in the house. We feel that the original location would have taken away from the clean look of the house, as it required a very large stack with supports. We were also able to move many of the building materials out of the elements and organize them inside.
(https://lh3.googleusercontent.com/-f3BIZT_wj7c/UStz5ZHXqmI/AAAAAAAABbQ/tc-o8nhW-oc/s519/DSC01087.JPG)(https://lh4.googleusercontent.com/-scoSSbuRd34/USt0OYzQZDI/AAAAAAAABbo/He7kCbCgdb4/s519/DSC01089.JPG)
(https://lh4.googleusercontent.com/-lJB3BHBdZys/USt0PGVjVFI/AAAAAAAABbw/tuD9oH5n8WA/s692/DSC01090.JPG)
(https://lh3.googleusercontent.com/-1kJIoH8wAM4/USt0c8Lh2XI/AAAAAAAABcQ/KfHsKdhXdow/s519/DSC01091.JPG)(https://lh4.googleusercontent.com/-3eNLNSnFDk8/USt0boGvJ3I/AAAAAAAABcI/cKZ12JZ4vts/s519/DSC01092.JPG)
(https://lh4.googleusercontent.com/-HSM1RRoDwxA/USt0rr5Bn_I/AAAAAAAABcg/x4oNcjqdm0g/s692/DSC01095.JPG)
(https://lh4.googleusercontent.com/-sEeYec1zTQY/USt0s2Mq4PI/AAAAAAAABco/IkNJbLRayIU/s519/DSC01096.JPG)(https://lh3.googleusercontent.com/-nxbVq6_8a6g/USt04XA73pI/AAAAAAAABcw/pq1c2kBQLFY/s519/DSC01097.JPG)
(https://lh6.googleusercontent.com/-K2WMaH-phHQ/USt06JkZqAI/AAAAAAAABdA/u3yyDKbtC94/s692/DSC01098.JPG)
(https://lh4.googleusercontent.com/-QPaz3U7mNP4/USt09kQhjiI/AAAAAAAABdI/e_dO5Kh6GdU/s692/DSC01100.JPG)
Nice work. Its wonderful.
Wow !!! . . . Now that's really somethin' . . .
Pictures from the weekend.
They made good progress with siding, and some soffits and fascia. High winds and snow prevented further progress.
(https://lh6.googleusercontent.com/-kQVhRQ1RFu8/UTTR0bRbBXI/AAAAAAAABd8/lAnCyjFjff8/s692/DSC01101.JPG)
(https://lh3.googleusercontent.com/-6s7Lj_7z9XM/UTTR37EerBI/AAAAAAAABeM/0iUy5m9ZdLk/s692/DSC01103.JPG)
(https://lh4.googleusercontent.com/-w01wVzv3osA/UTTSH5h_OgI/AAAAAAAABec/P_F5p0R4QFo/s692/DSC01104.JPG)
(https://lh3.googleusercontent.com/-X5zVTUFZaNI/UTTSQZeAe_I/AAAAAAAABek/Hz_MF_SmOw8/s692/DSC01106.JPG)
My wife and I started work on the plumbing. The upstairs tub and shower stall pan is in and connected. The corner tub was especially tricky, as the drain was on one side of a floor truss, and the overflow on the other. It's difficult to see, but there was just enough room to straddle the truss and run the overflow through the webbing to rejoin before the trap.
(https://lh3.googleusercontent.com/-FcQLEgR1KHU/UTTSZePWNGI/AAAAAAAABes/wDJ6fvASpww/s519/DSC01108.JPG)
(https://lh6.googleusercontent.com/-ANHKPCIN-Bs/UTTScX5HrpI/AAAAAAAABe0/dTjBsBXIp2w/s692/DSC01107.JPG)
(https://lh4.googleusercontent.com/-DyNygroejXk/UTTSqfBZN3I/AAAAAAAABfE/UOgn9evYfQw/s692/DSC01110.JPG)
(https://lh6.googleusercontent.com/-pbq6LIxamFA/UTTSsUB3LcI/AAAAAAAABfM/f1IZfpulsaA/s692/DSC01111.JPG)
My helper.
(https://lh6.googleusercontent.com/-CCFTw86kLQM/UTTSv5M9RYI/AAAAAAAABfU/CEpD668KzQU/s692/DSC01112.JPG)
On the way home, we passed a very large snowman.
(https://lh5.googleusercontent.com/-PRm7T8bjWPY/UTTTB39u1lI/AAAAAAAABf0/PHnDWFXxFxA/s519/DSC01116.JPG)
The story had a sad start but OMG - your build looks superb at this point. And what a wonderful lot!
My wife and I fell in love with this last night when I showed here the pics. I'm leaning towards a full basement and 1 1/2 story but things very fluid yet- really would love to attempt a Victorian but sense it beyond my ability. And my hopes are to do a fair amount of the build myself. I have plenty of time as we are both in the process of retiring this spring.
I am new here and pretty much a hands on guy but a rooky too at building an actual house.
If you don't mind I may be asked many questions of you and others here. I am looking for a land parcel either in northern MN
or in MI/WI border area. And the UP remains on our radar too as when one gets away to a point another 60 -80 miles is nuttin' !! :)
Thanks for the kind words. Feel free to ask away. I'll defer many of the construction questions myself, as we hired out the "shell" work, but we are doing most of the other work. It really is a wonderful area, and the lot prices can't be beat.
On another note, my work computer needs some maintenance, so I will be taking advantage of this time and using some vacation days this week. I'm heading North tomorrow and plan to stay onsite until Sunday. The plan is to setup "camp" in one of the upper rooms-tent and all! I'll be sure to take lots of pictures.
Time to post some progress pictures! The time spent there was shorter than expected, but much was accomplished.
The roofing on the existing structure is nearly complete.
(https://lh3.googleusercontent.com/-Ul-598dPlGY/UT0v8V-4PmI/AAAAAAAABgg/PXh9r-NluZM/s945/%5BUNSET%5D)
(https://lh5.googleusercontent.com/-mk3KMrjch1E/UT0v_FAt4WI/AAAAAAAABg4/kc7386nAxcs/s945/%5BUNSET%5D)
Good progress was also made on the plumbing.
Kitchen Sink
(https://lh6.googleusercontent.com/-JN_nrrxkSqM/UT0wDMRWTqI/AAAAAAAABhY/xvvz4Q8FpY8/s532/%5BUNSET%5D)(https://lh3.googleusercontent.com/-_M3Tg-MR3w4/UT0wEAmPSSI/AAAAAAAABhg/anyxT9W1lmI/s532/%5BUNSET%5D)
Bathroom Sink Stack
(https://lh4.googleusercontent.com/-oSCQWlrUkt4/UT0wFsAgP0I/AAAAAAAABho/m8Y9HA1ygB8/s532/%5BUNSET%5D)
Bath Sink Stack Vent Merge
(https://lh3.googleusercontent.com/-tRdBrhoxyyI/UT0wHJG76NI/AAAAAAAABh4/ggaaMvuZ-v0/s532/%5BUNSET%5D)
Upstairs Toilet-this was tricky. The location of the drain was a bit to close to the wall to clear the tank, but immediately in front of the drain location is a double floor truss. To solve this problem, the tank is going to project into the wall a bit, which is why the studs have been removed. T&G is going to be installed behind this toilet to cover and provide support for the stairwell drywall.
(https://lh5.googleusercontent.com/-xW4gDTJ-zuk/UT0wIJjRYyI/AAAAAAAABiA/m-iE-q2yLXc/s945/%5BUNSET%5D)
Upstairs Shower Trap, Shower and Bath Vent, along with the Kitchen Sink Vent.
(https://lh5.googleusercontent.com/-MgKiSe6gWKU/UT0wI1ECIFI/AAAAAAAABiI/VuMgPZjT85U/s945/%5BUNSET%5D)
Kitchen Sink Vent merges with Bath/Shower Vent
(https://lh5.googleusercontent.com/-a_b_vekB_Ag/UT0wMX5M5TI/AAAAAAAABio/prOUKbjBCBw/s532/%5BUNSET%5D)
Sanitary Tee for 2nd Floor Toilet
(https://lh5.googleusercontent.com/-7fR96RLyKUo/UT0wJkyLStI/AAAAAAAABiQ/DNV_B_coyEY/s945/%5BUNSET%5D)
Thursday Morning View
(https://lh3.googleusercontent.com/-K23CTMBoV3k/UT0wOHF5zOI/AAAAAAAABi4/S0gNnMJqXcQ/s945/%5BUNSET%5D)
Probably a little late to mention but they do make an "offset" toilet flange that will give you a couple inches.
I had never heard of those, very interesting. Thanks for the suggestion! Now that I did the work, I think I'll stick with my other plan, as it has an added benefit of having the toilet project into the room less.
http://www.grainger.com/Grainger/OATEY-Toilet-Flange-4KMN5?gclid=CPT0m-vK9LUCFaZQOgodHlUAYA&cm_mmc=PPC:GooglePLA-_-Plumbing-_-Toilets/Urinals-_-4KMN5&ci_src=17588969&ci_sku=4KMN5&ef_id=UM3ybgAARHKm6h47:20130311114311:s
I have some fantastic news! My initial contractor gave me a full refund! I had to play some serious hardball, but it was well worth it. While I did get the basement footings and walls out of the deal, what it will cost to seal and properly grade exceeds any value it had, making it a wash. It also means I won't be paying for the basement floor and porch footings twice!
The basement floor went in last week. I hope to post pictures soon.
While waiting for spring to arrive progress was slow. I spent a great deal of time working on the pex installation for in-floor heat. It's a very tedious process, but I suspect it will be worth it in the end.
(https://lh4.googleusercontent.com/-TQ8dzT-6hKc/Ua84EHn0ukI/AAAAAAAABvM/a9QKtYRxpvk/w312-h553-no/IMG_20130425_165504_184) (https://lh5.googleusercontent.com/-nd39NC73Row/Ua84F9B2sEI/AAAAAAAABvc/iez_ALoewnU/w312-h553-no/IMG_20130425_165452_673)
The basement floor was also installed-though I just realized I didn't take a finished picture yet.
(https://lh6.googleusercontent.com/tz0mr30Saqe-EoXiWrqyY6BCV6T_ayL7LJo9MQXYH_0=w338-h190-p-no) (https://lh6.googleusercontent.com/hJ04NZkM_blwuwRNBzYQ3LS8v7Ii5-Lrvf74gMS8XLE=w337-h190-p-no)
(https://lh6.googleusercontent.com/wEd0lMbBSojLvBJe-ni7H8dY1b_dHEecgHb43Mr1s8A=w337-h190-p-no) (https://lh4.googleusercontent.com/7xUf-4hncIiKBZTVXCjymFrftlHzmzvI6VpEs1NP5nk=w337-h190-p-no)
On Monday, the septic installation started.
(https://lh6.googleusercontent.com/oMnt5rsN5m374NN4hJKrcvbdTyc6AwK7wcx32Qz11ps=w337-h190-p-no) (https://lh4.googleusercontent.com/jbT9VCNiM7MoQFISKqQQbaZePEzjy1m37ifE4loRvGE=w337-h190-p-no) (https://lh4.googleusercontent.com/FjjNHJXI0-vcytYTv6YaRw8eK72RTvUd0k_yZh0vaQw=w337-h190-p-no)
(https://lh6.googleusercontent.com/C6NNLzXTE1MogGyjO0Ie7F7BNeGjtkEFFBBJvXcxr7k=w337-h190-p-no) (https://lh4.googleusercontent.com/rw11Jp9sUU_kHlbHlXiyQ8-l2VQdIi04otX02e-nWIw=w337-h190-p-no) (https://lh4.googleusercontent.com/qoT-fBRvP127R0M9vu-VwRxJCk91nxbVW6Zk0NNtGeU=w371-h208-p-no)
As you can see from some of the pictures, the soil has a very high clay content. Sand was taken from this hill when the highway was built, and was replaced by this clay fill. Because of this, we needed to install an "undercut" or "inverted mound" system. The original plan was to truck in material, however, when I mentioned that I someday wanted to dig a pond in a low area, we decided that since the area originally was sand, it was worth moving a few buckets from the low area to see what was there. Just below the surface, we hit sand, which will work perfectly in the drain field. I'm really excited about this, because with the cost of the septic, I get the start of a pond.
Here is the excavator stripping the topsoil off of the pond area.
(https://lh6.googleusercontent.com/-JlqGDYoqv8Q/Ua83sV-OxPI/AAAAAAAABsM/EmuPpQtLDBo/w980-h553-no/IMG_20130603_162302_693)
Here is how the building site looked as of Monday night. My job calls, so I won't be there for the rest of the install.
(https://lh4.googleusercontent.com/-HtQqgjTFe1I/Ua83jcB465I/AAAAAAAABrs/OHy5Vkd1uxM/w980-h553-no/IMG_20130603_174958_721)
Looking great! I cant wait to see the rest. we are doing pexx too. We decidie that we were going to do a mix of cedar panneling and dry wall so we can hang art work. we are going to spend more on our bathroomand our matsersuite because it is our private spot. I hope to see your palce finished. [cool]
These forms will be of interest to those using pier foundations-they are sometimes called "big foots" They add a little more stability and make the pier less susceptible to frost heave. I will be building my covered porch on these, after they are filled with concrete of course. ;)
(https://lh3.googleusercontent.com/-IWxp6JTngm4/Ua83l50aH0I/AAAAAAAABr8/YWzUnF9YYkw/w312-h553-no/IMG_20130603_172640_965)
Not to be cranky, but Bigfoot is a brand name and what you are using appears to be a Sonotube product and square vs. round. http://www.bigfootsystems.com/
Irregardless of the product name the frost heave will occur with either. Just make sure that the bottom of the tube is below the frost level (freeze depth). The platforms do make it a little more stable w/o frost issue.
Quote from: poppy on June 05, 2013, 12:12:11 PM
You are correct, hence my "
sometimes called big foots"
Sonotube calls them a "Square concrete footing" http://www.menards.com/main/building-materials/concrete-cement-masonry/forming-tubes/28-sonotube-square-concrete-footing/p-1398448-c-5652.htm (http://www.menards.com/main/building-materials/concrete-cement-masonry/forming-tubes/28-sonotube-square-concrete-footing/p-1398448-c-5652.htm)
Quote from: Redoverfarm on June 05, 2013, 12:34:48 PM
I used to think the same thing, but occasionally frost/ice can "grab" the piers from the side and lift-or so the locals say. Is it true?-I'm not sure, some google search results indicate it happens, so better safe than sorry, especially when extra stability comes with it.
A very productive weekend, thanks to family. My dad joined me, and we picked up my uncle who arrived in this:
(https://lh6.googleusercontent.com/-HO7dlV_PrXU/UbPe_bpXykI/AAAAAAAABxU/3RA54S1h8uE/w1023-h577-no/IMG_20130608_063849_162)
The septic system was completed upon my arrival, along with the forms placed for the porch footings. I was really glad I had the septic company dig and place them while they were there-the cost was VERY minimal because the backhoe made quick work of it. I was very pleased with their work, and they used the large rocks they uncovered to surround the drainfield-a smart and attractive way to prevent someone from accidentally driving on it.
(https://lh5.googleusercontent.com/-u25P6QRSESU/UbPekHOtZzI/AAAAAAAABw8/sRkVWotVmkg/w1023-h577-no/IMG_20130608_154209_157)
Pouring the footings went much faster than I expected. The concrete truck operator easily lined up the chute and made quick work of filling the forms. Because of this, I have no pictures of the work being performed, only the finished product.
(https://lh6.googleusercontent.com/-oUDfXdeThI0/UbPeX457LsI/AAAAAAAABw0/fwcjZJOtCaQ/w1023-h577-no/IMG_20130608_154216_261)
(https://lh3.googleusercontent.com/ydFvohzIt8oiRaixR2C6E1W_pAieoYpDInbcJZ7TM-I=w337-h190-p-no) (https://lh6.googleusercontent.com/q2Uqv1zjFZaKmV2c8-zzL0F3q59rlHxePtXBlxBDYM0=w338-h190-p-no)
The extra concrete was used to pour a small slab. We build a form with a movable divide where I plan to have a shed. Depending on how much concrete was left, we could adjust the divide to accommodate the concrete volume. I ended up with a 4x8 slab, which I will likely use for a covered woodshed. I highly recommend this to others who are having concrete delivered. It's always smart to order extra, and this is a great way to make use of it.
After the pour, we started the electrical rough in for the kitchen and living room, completing nearly all of the outlets. No pictures of that yet.
At the end of the day, I was lucky enough to have the opportunity to view my project from a very different perspective.
(https://lh5.googleusercontent.com/-Gvni7k8y3V8/UbPeDz9GIJI/AAAAAAAABwk/I1y8qBNAKuA/w1023-h577-no/IMG_20130608_171252_794)
(https://lh6.googleusercontent.com/-x1Jl_RNSjaY/UbPdyg4WkZI/AAAAAAAABwU/PvVRmyMcsGk/w1023-h577-no/IMG_20130608_171303_789)
(https://lh6.googleusercontent.com/-fhoH85URlsY/UbPdqYY5xYI/AAAAAAAABwM/foVGQnJGjJA/w1023-h577-no/IMG_20130608_171311_095)
A great many thanks to my Dad and my Uncle Bill. It was a great day.
Being a straight chap and avoiding substances for many years makes me want to get "high" like THIS!
Cool pics and dang nice build....sweet! :)
IT IS ABSOLUTELY BREATH TAKING AND THE PRIVACY EXQUISITE!
It's been too long since I posted an update. I'm actually tracking my build on another website, so I'm going to put the link here. I apologize for the cross post, I just don't have time to post in both spots these days :)
http://www.homesteadingtoday.com/homestead-construction/487777-our-northwoods-homestead-2.html (http://www.homesteadingtoday.com/homestead-construction/487777-our-northwoods-homestead-2.html)
(https://lh3.googleusercontent.com/-Qm-TheM26z8/UhkgdLCPVkI/AAAAAAAACEg/LV8P7i9sIoM/w751-h563-no/DSC01174.JPG)
great view of a awsome getaway , if its possible, give us an expence report plz. i like to see what people pay in diff parts of the world. especially intrested in what the radient cost you.thx
[cool] [cool] [cool] [cool] [cool] c*
you slippery little stinker you.....been wondering where you been hiding. Absolutely beautiful!
Did ya sell the WI place then or ??? My guess is you are in the new place FT now??? Guess I gotta chase down the other thread now.....great to hear from you.
Still in Northern Wisconsin, but hope to be in the new place by the end of the year. Rather than move in and have to juggle personal belongings, we thought it best to finish as much as possible before moving in. Still a ways to go on the interior. Drywall started this week, and I hope to get a good start on the tongue and groove ceilings with my Dad/uncle this weekend.
Lots of changes(good) these days-and we are busier than ever!
Quote from: mgramann on September 12, 2013, 08:59:46 AM
Hope you are planning to pre-finish the ceiling before install. It makes it a lot easier and gives a better finished product.
The wood is coming finished. I did the math, and with the volume discount I received, it cost an extra $300 compared to unfinished wood, poly and finishing it myself. I considered it money well spent.
I followed you to other thread link also - nice work my man, nice work.
Happy you kept us in the loop here too. Your place is mighty nice! :)
Still busy as ever, but I can't forget the place where I bought my plans!
http://www.homesteadingtoday.com/homestead-construction/487777-our-northwoods-homestead-3.html (http://www.homesteadingtoday.com/homestead-construction/487777-our-northwoods-homestead-3.html)
We are especially excited about the new addition!
Fantastic my man - the house for sure but even more so on the new addition. Yoooohoooooooo!
Congrats to both of you as you take yet another fork in the road to your dreams.
Happy for you all!!!!!! [cool] [cool] [cool] ;D
More updates to share!
http://www.homesteadingtoday.com/homestead-construction/487777-our-northwoods-homestead-5.html (http://www.homesteadingtoday.com/homestead-construction/487777-our-northwoods-homestead-5.html)
