Need to help son with his hot roof in Vermont. Here are the layers starting from the ceiling to shingles:
The ceiling is 2x8 tongue and groove hemlock. You can see rot near the eve.
Particle Board 1/2"
1x1" strips with fiberglass insulation in-between.
plywood
tar paper
foam board
plywood
asphalt shingles.
How should we re-roof?
Thanks.
Ken
Do these links work?
https://photos.app.goo.gl/Sfhgu2pG2zrsys8U8
https://photos.app.goo.gl/G9yTxVv3T4fmZrBc8
https://photos.app.goo.gl/cg3byAx5U5Ap67YRA
the links do not lead to images. There is a trick to posting google user content to forums. Alas, I forget what it is... d*
Here is what I did based on the topic in the forum news:
"Google images can be difficult to use for forum posts. Try having the image open large on the screen and the right click on the image and copy the image address. NOT the url from the address bar."
Repair or replace lower course of hemlock. It won't look good inside, consider total replacement.
Then typically tarpaper, foam with edges offset and taped, sleepers, osb, finish roofing
Also just to add, no amount of insulation will protect a hot roof from ice dams and rot in Vermont. You have to ventilate on top of the insulation. At the eave and peak you should have a way to let the air in and out from between those sleepers.
You also want an air tight roof, don't let that warm air leak out from inside. Connecting the eave air barrier to wall would be an important detail... eaves are high risk. Also the black areas at the peak on the plywood look like there may have been air leakage issues up there causing mold and rot.
buildingscience.com has a lot of good info on doing it right and explaining roof failures.
