Internet Finds for Designer/Builders => Referral Links => Topic started by: MountainDon on April 02, 2007, 05:35:41 PM
Title: CALC: AWC Joist & Rafter Span Calculator
Post by: MountainDon on April 02, 2007, 05:35:41 PM
This is an online calculator for joist and rafter spans. It takes into account wood species, size and grade, defelction linits, spacing, loads, etc. It's a marvelous tool and all the more because it is free for use.  :o
NOTE: This is a wonderfully handy calculator. I like it better than the tables that can also be used. Like the simple tables the rafter solutions are for rafters with the rafters ties or ceiling joists located at the rafter to wall joint. If the rafter ties are elevated corrections must be applied to the rafter sizes. The corrections may be found in the building code tables.
Title: Re: AWC Joist & Rafter Span Calculator
Post by: John Raabe on August 05, 2008, 09:47:46 AM
(https://countryplans.com/smf/proxy.php?request=http%3A%2F%2Fi56.photobucket.com%2Falbums%2Fg166%2Fjraabe%2Fsh.jpg&hash=88eeea75c1bc21764fe0c65c359d1b27)Yep, this one is the best. Here is a tutorial I did on how to use it...
http://www.planhelp.com/public/98.cfm
This is a free article from our sister site PlanHelp.com (http://www.planhelp.com/public/main.cfm)
Post by: Mad Dog on August 08, 2008, 06:47:18 AM
That answered a couple questions I had, thanks for the info. [cool]
Files included: 31 - 893KB. (show)
Cache hits: 8: 0.00209s for 34,862 bytes (show)
Queries used: 14.
