Jeff Milstein's 1972 preassembled cabin plans. This is a large zip file that will unzip into five PDF files - one for each sheet of the plans. These can then be viewed in Acrobat Reader and printed in sections to your own printer.
To print full sized scaled plans, copy the PDF files to a CD or USB drive and take them to a copy shop for printing on 24"x 36" sheets.
This is a great plan for ideas, especially about a preassembled small cabin. These plans are over 35 years old and are not designed for and do not meet most building codes. They are offered for historic and artistic interest only. NOT FOR CONSTRUCTION.
This is a large zip file that will unzip into five PDF files - one for each sheet of the plans. Save this file in a download area of your own computer and unzip the files there. These can then be viewed in Acrobat Reader and printed in sections to your own printer.
Jeff Milstein, the designer, has freely allowed us to post these historic plans. Here is his note:
"The design of the structure on these plans is 34 years old and for many reasons can no longer be endoresed as a structure for living. The design does not meet building codes and uses materials (such as adhesives with formaldehyde) and construction techniques no longer endorsed for home use. If I were to design this building today I would do things differently using todays materials and techniques. That said, you may review these plans as an artistic or historical document but NOT FOR CONSTRUCTION."
