One good thing, other than the price is the engine has a cast iron sleeve. Chances are it'll be good value.It will most likely also be noisy as there are no claims to any particular sound level in the specs and it runs at 3600 RPM's at all times. Hopefully if you plan on running it a lot you can place it some distance from where you will be.
