CountryPlans Design/Build Forum Building & Design help for the involved home owner
September 10, 2010, 07:32:04 AM *
Welcome, Guest. Please login or register.
Did you miss your activation email?
Login with username, password and session length
News: Welcome to the Small Home & Cabin Design/Build Forum!
• Feel free to ask & answer questions about building smaller homes, cottages, and cabins.
No Advertising - You may post a web link in your profile.
• Signup for free and start posting. Click REGISTER.
• Click PROFILE SETUP to update your membership data.
• Click SEARCH to find a topic quickly.
• Click HOME to return to the main CountryPlans.com website and our PLANS.
   Home   Help Search Login Register
Pages: [1]   Go Down
  Print
Author Topic: Heating the 2nd floor  (Read 336 times)
dougpete
Junior Member
Offline Offline
« on: May 19, 2010, 02:54:17 PM »
Greetings -
We have started framing the basic two story (expanded to 24' wide) over a full basement.  I plan primarily heating with wood, with a heat pump as back up.  We actually need the hvac to help manage humidity more than anything else.
Since we have 9' basement walls, running ductwork for the 1st floor should be simple, what is the best way to run ducts to the bedrooms on the second floor?
Doug
Logged
Journeyman
Offline Offline
Gender: Male
Applachian Mtns, West Virginia
« Reply #1 on: May 19, 2010, 04:39:00 PM »
Doug it all depends on your floor plan and layout.  Generally there is a chase provided for the duct from the fan to the upstairs. Most are done in closets of the first floor and branches off in the 2nd.  Open 2nd floor?  You will probably need a cold air return unless it is fairly open to allow it to fall or be drawn to the first floor via stairs and a return located nearby.
Logged
Administrator
Journeyman
Offline Offline
Gender: Male
Whidbey Island, WA
WWW
« Reply #2 on: May 20, 2010, 05:53:44 PM »
I would suggest calling out a local HVAC installer to determine the layout and to choose the best type of system to install. The best equipment for the climate, fuel costs, etc. is often a pretty local decision.
Logged
Sourdo
Apprentice
Offline Offline
« Reply #3 on: July 17, 2010, 07:20:01 AM »
Consider a Monitor or Toyo that runs on stove oil. Very, very efficient. I'm going to use just one to heat the whole place of my 1-1/2 story cottage. So the reason for having a partial open ceiling. I'll use reversable ceiling fans and cold air ducts. I have one now in the old trailer I'm living in while I build, it is amazingly stingy on the fuel use.
Electricity up here in Alaska is a bit high in cost and not really a viable option for heat.
Russ
Logged
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
