Author Topic: bracket for 6x6 post?  (Read 6094 times)
Offline tesa
« on: April 11, 2010, 05:40:31 AM »
so the anchor bolt goes into the concrete, then we attach a bracket for the post to sit in/on?
on my materials list, one is ac, and one is ace6
if i go to the simpson website, will they have pictures of them listed, i can't seem to see in my mind
what these brackets do
tesa
"building a house requires thousands of decisions based on a million bits of information"-charlie wing
Offline diyfrank
Re: bracket for 6x6 post?
« Reply #1 on: April 11, 2010, 05:49:05 AM »
Their web site does shows pictures. You may be able to get the catalog for free from Lowe's or home depot.
 I have one and think it's easier than looking online for what I need.
Home is where you make it
Offline MikeT
  • "The best is the enemy of good." Voltaire (1764)
« Reply #2 on: April 11, 2010, 06:10:12 AM »
I may be off base here, but I think the brackets that you are referring to do not have anything to do with the anchor bolts and any foundation connection.  These are for the top of a 6x post where a beam is then connected.  The ACE6 is for a connection where the post hits the end of said beam.  And the AC is for a connection where a post is holding up a beam at a point in the middle of the beam.
At least that is how I would interpret things.
mt
Offline glenn kangiser
  • The Troglodyte
    • Underground Cabin
« Reply #3 on: April 11, 2010, 06:18:30 AM »
Simpson has good online pix and a catalog you can download - here is a link
http://strongtie.com/
Offline tesa
« Reply #4 on: April 11, 2010, 07:35:30 AM »
i thought the simpson brackets called for in the plans were for the tops of the posts, but it seemed odd that the only thing
holding our post to our footer would be one anchor bolt, but then again, this is my first rodeo
tesa
Offline PEG688
  • Master Craftsman
  • Whidbey Island , Wa.
« Reply #5 on: April 11, 2010, 07:41:26 AM »
  The AC series are wood to wood connectors :
   Down at the post bottom you're looking at this type connector:
 Or a different one that uses a bolt:
 The AB series is one to look at either on the site Glenn linked or in the catalog.
 G/L PEG
