CountryPlans Design/Build Forum Building & Design help for the involved home owner
July 30, 2010, 11:39:12 AM *
Welcome, Guest. Please login or register.
Did you miss your activation email?
Login with username, password and session length
News: Welcome to the Small Home & Cabin Design/Build Forum!
• Feel free to ask & answer questions about building smaller homes, cottages, and cabins.
No Advertising - You may post a web link in your profile.
• Signup for free and start posting. Click REGISTER.
• Click PROFILE SETUP to update your membership data.
• Click SEARCH to find a topic quickly.
• Click HOME to return to the main CountryPlans.com website and our PLANS.
   Home   Help Search Login Register
Pages: [1] 2   Go Down
  Print
Author Topic: Simpson Bracket for Beam ?  (Read 3166 times)
peteh2833
Senior Member
Offline Offline
Gender: Male
Camp in Tionesta Pa
« on: November 24, 2007, 01:03:34 PM »
I am building the 1.5 story 20x30  camp. I have the piers done. I will be setting the built up beams directly on the concrete pier. What bracket should I use to anchor them to the pier? The beams will be 3 2x10's with 1/2 inch plywood in between. Thanks Pete
Logged
Pittsburgh Pa for home
Tionesta Pa for Camp
Master Craftsman
Journeyman
Offline Offline
Whidbey Island , Wa.
« Reply #1 on: November 24, 2007, 03:00:17 PM »
 A CB66 would be nice ,
 Or another version that would work would be ,
 I think it's obvious the CB is stronger.
 So your planning on no post , meaning your piers will all be perfectly level to each other and poured at exactly the right height!  You sure about that?
Logged
peteh2833
Senior Member
Offline Offline
Gender: Male
Camp in Tionesta Pa
« Reply #2 on: November 24, 2007, 03:04:32 PM »
The piers are already poured so i can't use the CB  correct?Huh?
Logged
Spam Hunter
Administrator
Journeyman
Offline Offline
Gender: Male
Jemez Mountains, NM; that's pronounced HEY-mess
WWW
« Reply #3 on: November 24, 2007, 03:07:11 PM »
I was just going to ask that question. No, CB66's would be difficult to impossible now.
What are the piers; poured concrete in a form, concrete blocks, round, square...?? size?
Logged
My Cabin Topic
Stop  Spam: use Report to Moderator link at bottom of forum posts.
Master Craftsman
Journeyman
Offline Offline
« Reply #4 on: November 24, 2007, 03:09:09 PM »
 Opps  toilet lets flush the CB66  rofl .
 All ready poured humm , any photo's ? I'm sure there's a fix , so no bolt / rebar / nuttin sticking out of the pier top , just a concrete post? Rebar poured inside it  Huh?
Logged
Spam Hunter
Administrator
Journeyman
Offline Offline
Gender: Male
WWW
« Reply #5 on: November 24, 2007, 03:11:10 PM »
Nice use of the new smileys, Paul   cool
Logged
My Cabin Topic
Master Craftsman
Journeyman
Offline Offline
« Reply #6 on: November 24, 2007, 03:16:49 PM »
 Thanks Mtn D  Grin
 peteh the second bracket I posted is epoxied in , or can be , it just happened the image I put up is shown epoxied into the pre poured pier / post / slab.
Logged
Spam Hunter
Administrator
Journeyman
Offline Offline
Gender: Male
WWW
« Reply #7 on: November 24, 2007, 03:18:47 PM »
Is that EPB available in a 5 1/2" wide configuration?  hmm (Can't find my simpson catalog  duhh )
« Last Edit: November 24, 2007, 03:46:08 PM by MountainDon » Logged
My Cabin Topic
Spam Hunter
Administrator
Journeyman
Offline Offline
Gender: Male
WWW
« Reply #8 on: November 24, 2007, 03:26:31 PM »
I found the catalog and it appears that the EPB is only available as EPB44, for 4x4 posts.
Maybe an AB66 would work?  hmm Just need to drill the proper size hole and epoxy in an anchor bolt it uplift forces are a concern. It wouldn't offer much in the way of tipping resistance, but once the joists are secured that wouldn't matter as much.
Are you in a code compliance location?
Logged
My Cabin Topic
Master Craftsman
Journeyman
Offline Offline
« Reply #9 on: November 24, 2007, 03:33:09 PM »
 Good point Mtn. D alway start in the beginning  duhh
Logged
peteh2833
Senior Member
Offline Offline
Gender: Male
Camp in Tionesta Pa
« Reply #10 on: November 24, 2007, 03:39:03 PM »
OK
Peg688, I poured 10" round tubes. I made 18"x18" and 6" deep footers about 40 inches down. I added to 2 pieces of rebar about 2 to 3 feet long going from the footer up into the tube. I didn't put the brackets in when it was wet because I wanted to make sure everything was square. Would the bracket work best or epoxy a piece of all thread into each pier and then up into each built up beam? I have pictures but they are home on my computer and I'm at work now. I can post later. Thanks Pete
Also no code compliance. No inspection.
« Last Edit: November 24, 2007, 03:56:13 PM by peteh2833 » Logged
peteh2833
Senior Member
Offline Offline
Gender: Male
Camp in Tionesta Pa
« Reply #11 on: November 24, 2007, 03:51:40 PM »
My Uncle helped and is an experienced carpenter. I'm building this camp right next to a smaller camp that is already there and will eventually be attached by way of a breezeway. We used a water level to mark each tube after they were set. We then cut each tube down to the mark and poured them. They should be all level. Pete
« Last Edit: November 24, 2007, 03:54:12 PM by MountainDon » Logged
Spam Hunter
Administrator
Journeyman
Offline Offline
Gender: Male
WWW
« Reply #12 on: November 24, 2007, 03:53:03 PM »
I did put the brackets in when it was wet because I wanted to make sure everything was square.
I'm not following that statement? Should that read "did not put" ?
Logged
My Cabin Topic
peteh2833
Senior Member
Offline Offline
Gender: Male
Camp in Tionesta Pa
« Reply #13 on: November 24, 2007, 03:57:15 PM »
Sorry I fixed it. It should have been didn't.
Logged
Master Craftsman
Journeyman
Offline Offline
« Reply #14 on: November 24, 2007, 04:01:16 PM »
 That's what I was trying to figger out as well Don Huh?
 I assume did NOT was intended.
 Well with no code to meet and what you've described is a solid post and pier setup , I'd epoxy into the pier a piece of Galv. threaded 5/8 rod into the concrete at least 8 " that sticks up at least 1" above the beam tops ( if it's to long you can cut it off , the projecting rod , later with a sawsall) then you could use a piece of steel bar stock 1/4 thick and as wide as you built up beam , so a 1/4"x 5 1/2" x 5 1/2" steel washer at each post to beam connection .
Logged
peteh2833
Senior Member
Offline Offline
Gender: Male
Camp in Tionesta Pa
« Reply #15 on: November 24, 2007, 04:08:11 PM »
Thanks for the compliments on the solid base. I was wondering if it was good enough!!!
I understand the part about the all thread. drill into the pier and then drill through the beam. The 1/4 steel stock is the hangup. Do u mean make a square washer as wide as the beam out of the 1/4 stock and then put that on top of the all thread and tighten it down with a nut?
Logged
Master Craftsman
Journeyman
Offline Offline
« Reply #16 on: November 24, 2007, 04:33:39 PM »
 YUP! That will hold"er" down and stop it from tipping over. I'm no engineer but you don't need one if you have no code to meet . Ask your uncle what his plan was , he may have a better idea , but I'm sure that threaded rod and washer / nut setup will meet and /or exceed your needs for a positive tie.
Logged
peteh2833
Senior Member
Offline Offline
Gender: Male
Camp in Tionesta Pa
« Reply #17 on: November 24, 2007, 04:55:26 PM »
I'm pretty sure that is what he had planned. He won't always be there to assist me so I figured I should get a start on it. Thanks Peg688 for all the help. You too Mountain Don
What do you recommend putting between the beam and the concrete as a barrier? Also do you think I should use pressure treated for the beam and joists???
Logged
Master Craftsman
Journeyman
Offline Offline
« Reply #18 on: November 24, 2007, 05:12:25 PM »
 #1: What do you recommend putting between the beam and the concrete as a barrier?
 #2: Also do you think I should use pressure treated for the beam and joists???
 #1: 30 lbs felt or a piece of comp shingle.
 #2: Not needed if it's all under the cabin , no cantilevered deck joist or other "uncovered " porch ares are there?  If that answer is no the PT lumber is not needed.
 You are up in the air /off the ground  at least  6 " minimum  right?
Logged
peteh2833
Senior Member
Offline Offline
Gender: Male
Camp in Tionesta Pa
« Reply #19 on: November 24, 2007, 06:21:18 PM »
No cantilevered areas or uncovered areas. It is up off of the ground by at least 6". Thanks for the help. My next problem to tackle is how to insulate the floor joists?
Logged
Pages: [1] 2   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
