Author Topic: Deer Run- 16x26 in Oklahoma  (Read 215675 times)
Offline John Raabe
  • Gender: Male
  • Whidbey Island, WA
    • CountryPlans.com About Us
Re: 16x26 in Oklahoma
« Reply #100 on: January 27, 2008, 05:11:51 PM »
It will be extra work but the idea merits study. It would be a charming ship-like interior space that would also allow you to increase the insulation value in the ceiling rafters.
Offline ScottA
  • No Edits
  • Gender: Male
« Reply #101 on: January 28, 2008, 12:20:06 PM »
Veranda posts and beams.
« Last Edit: February 17, 2012, 02:38:27 PM by ScottAarchive »
Offline glenn kangiser
  • The Troglodyte
  • Gender: Male
    • Underground Cabin
« Reply #102 on: January 28, 2008, 06:23:02 PM »
Looks good, Scott.  No concerns with them interfering with the view of the backhoe?
Offline ScottA
  • No Edits
  • Gender: Male
« Reply #103 on: January 28, 2008, 07:12:27 PM »
Damn I didn't think of that. Maybe if I park it just right it will be ok.
Offline ScottA
  • No Edits
  • Gender: Male
« Reply #104 on: February 02, 2008, 01:13:39 PM »
Another slow week. Weather to blame this time but it's comming along. Got the floor joists in for the sleeping loft and built the short wall around the loft. Sheathing and exterior walls are finaly finnished. Now the fun part starts.
« Last Edit: February 17, 2012, 02:38:46 PM by ScottAarchive »
Offline MountainDon
  • Gender: Male
    • My 15.75 x 30 Jemez Cabin
« Reply #105 on: February 05, 2008, 08:46:57 PM »
Question for you Scott; regarding the A/C over the fridge.
Is this for a regular window type A/C, but without an actual window? Curious because I haven't worked out the details for how I'm going to install a small A/C.
Offline ScottA
  • No Edits
  • Gender: Male
« Reply #106 on: February 06, 2008, 04:54:54 AM »
Yes Don it will be a window unit with all the trim stripped off. I did the same thing in my workshop and it worked fine. The framed hole is larger than needed in case I need to replace the unit later and can't get one the same size or if I want to put in a larger unit. Most models have remote control now so easy access is not needed.
  • The Troglodyte
  • Gender: Male
    • Underground Cabin
« Reply #107 on: February 06, 2008, 07:53:40 AM »
We have done the same at our other place -- works great.
Offline ScottA
  • No Edits
  • Gender: Male
« Reply #108 on: February 06, 2008, 08:48:02 AM »
Makes for a much neater install IMO. Window units in windows look awful.
Offline daybreakhuntin
  • Apprentice
« Reply #109 on: February 06, 2008, 09:27:49 AM »
Is your wall studs on 16 or 24 centers, they look a little big for 16.  Also what did you use for your subfloor? What are you plan on doing with the concrete blocks, leave them as is or put somthing over them. I thought of covering them with field stone would give a nice rustic look.
Offline Redoverfarm
  • Gender: Male
« Reply #110 on: February 06, 2008, 01:18:04 PM »
Scott did you get your round window? Went to the sale but on this date they didn't have any. They had the flex molding that goes around them. Someone bought some that I know just in case.
Offline ScottA
  • No Edits
  • Gender: Male
« Reply #111 on: February 06, 2008, 03:10:52 PM »
Studs are on 24" centers, subfloor is 23/32" OSB. The house gets a wrap around deck that will hide the blocks on 3 sides. Deck will be supported with large stones. The blocks that remain un-hidden I may cover with stone as you suggested. Undecided at this point.
I didn't have time to look for the round window yet. It's not a high priority at the moment. More concerned with building the roof. I'm a one man show so my time is tight.  :P
Offline mvk
  • Full Member
  • CountryPlans member south central New Hampshire
« Reply #112 on: February 09, 2008, 02:57:59 PM »
Scott
Wanted to take a minute to compliment you on your place you did a good job. But what I really think is that you nailed the floor plan and design, great job. Think my wife and me would kill each other in about a week in a place that size but I'm aware of all the advantages and again you really nailed it.
Are you going to do your barrel ceiling. How? Wood? I have played around with spruce/pine and fir over the years, spruce/pine on the flat and the fir on edge 3/4" revel, every 2nd or 3rd  or whatever board, gives you a little 3rd dimension  look. I thought it came out pretty nice and costumers liked it, didn't take much wood working skills so it was fairly cheap, but gave you a different look. Just a thought, one thing I learned is that you can love something and someone else can hate it.  I really  liked that scrape wood stair case that was posted and if it works out with the design, I do want to do some eyebrow dormers.
Thanks again for the advice you usually have some good ideas,  among many others I want to add
Mike
Offline ScottA
  • No Edits
  • Gender: Male
« Reply #113 on: February 09, 2008, 03:46:27 PM »
Thanks alot Mike. I worked on tweaking this floor plan for several months including doing some mock ups to try out the space. Right now it looks like the barrel cieling will be done with T&G white pine but plywood has also been suggested. I'm also thinking of possibly using hardwood flooring. We're going to incorporate some sort of bent trim work on the cieling as well for a 3d effect. The whole thing is still in the design stage so we'll see. Like everything else on this project, when the right idea pops up we know it and run with it. My wife and I share a tiny office so we're used to being close.
Offline Willy
  • Gender: Male
  • Fighting Wildland Fires for a Living! Okanogan, WA
« Reply #114 on: February 09, 2008, 06:31:52 PM »
Scott you cabin is coming along nice! I have been following in the posts. I am dieing to start mine if this snow would just go away!! Mark
Offline ScottA
  • No Edits
  • Gender: Male
« Reply #115 on: February 10, 2008, 06:31:34 PM »
Here is an example so you can get some idea what the barrel vault cieling will look like. We're hoping for a look very close to this. This will be in the sleeping loft area only. Framing is done by attaching plywood gusets, cut to the proper curve, to the framing. I think the radius will end up being 6'.
Peg will think I'm crazy for sure now.  d*
« Last Edit: February 17, 2012, 02:39:12 PM by ScottAarchive »
Offline ScottA
  • No Edits
  • Gender: Male
« Reply #116 on: February 10, 2008, 06:44:03 PM »
In the main living area I'm going to build a three trusses similar to the ones in this picture. They will be installed after the roof is on so the only thing structural about them will be to function as collar ties. I'll use some temporary ties to hold the walls plumb until these are installed.
« Last Edit: February 17, 2012, 02:39:30 PM by ScottAarchive »
  • Apprentice
« Reply #117 on: February 16, 2008, 01:14:48 PM »
Did you go with 10 ft side walls???
When pouring your concrete footings, what size did you pour?
Is your floor frame PT ?
Keep up the good work...
I live in Clarksville, AR probably 4 hrs from your location.
Offline travcojim
  • Junior Member
« Reply #118 on: February 16, 2008, 03:41:23 PM »
Not to hijack the thread, but I grew up there in the Clarksville area, actually Knoxville.  I am building outside of Kingston.
  • Apprentice
« Reply #119 on: February 16, 2008, 04:01:41 PM »
I grew up in the Scranton area and now live in Lamar, if I ever get a chance to build would hopefully by near the River
Offline ScottA
  • No Edits
  • Gender: Male
« Reply #120 on: February 16, 2008, 06:58:59 PM »
Side walls are framed with 9' precut studs (104 5/8").
Pier footings are aprox. 24x24x12" at the 4 corners and aprox. 20x20x12" on the other 11. Keep in mind these piers are sitting in clay/gravel which has a very strong bearing and is quite stable. In some of the holes I hit rock. The cabin is sitting on the crest of a narrow ridge so the soil is well drained. The bottom of the piers are about 18-24" below grade. The spoils from the holes where packed around the piers to increase the depth by about 4-6 more inches. The frost line here is less than 12"
The frame is not PT except in the veranda area.
Been a few days since an update...both lofts have been decked and the lumber for the roof is on site. Just waiting for a break in the rain to get going again.
  • Apprentice
« Reply #121 on: February 16, 2008, 07:06:46 PM »
Foundation beams are done. Weather is still crappy for over a week now. Starting on the floor tomorrow weather permiting.
Scott
How did you attach the beams to the piers, do you have any close up pics of this???
I like this block and beam design and trying to learn as much as possible.
Thanks again
« Last Edit: February 17, 2012, 02:40:01 PM by ScottAarchive »
Offline ScottA
  • No Edits
  • Gender: Male
« Reply #122 on: February 16, 2008, 07:57:28 PM »
Each pier has a long 1/2" anchor bolt set into it which passes through the framing. I used several sizes of washers to step up to a large (1 1/2" o.d.) washer and tighted the works down against the pier. There is an asphalt shingle on the top of each pier between the wood and the concrete.
You can kinda see the bolts in this pic. The beams are 3 boards wide everywhere else except this corner and the bolts come up in the center. Maybe not the perfect solution but it turned out pretty solid.
« Last Edit: February 17, 2012, 02:40:33 PM by ScottAarchive »
Offline ScottA
  • No Edits
  • Gender: Male
« Reply #123 on: February 18, 2008, 11:30:28 AM »
Started framing the roof today finaly  after a long delay.
I built a temporary bridge between the lofts to construct the roof.
No chemtrails today just bright blue sky.
Another look at my bridge from the sleeping loft.
Now if the weather will just cooperate maybe I can get this thing done.
« Last Edit: February 17, 2012, 02:41:22 PM by ScottAarchive »
Offline Homegrown Tomatoes
  • Gender: Female
« Reply #124 on: February 18, 2008, 01:06:59 PM »
Wow, you just started on the roof today?  I thought you were working alone?  I'm amazed at how quickly the whole thing has come up since the fall.  At the rate you're going, you'll have it dried in in no time at all.
