Working on making more flat spots here so I can move the usable unnatural resources from the other place before the thieves get it all. Seems old steel is worth enough now that a pile of unnatural resources down in the valley is no longer even semi-safe.Whitlock came over and helped me get the Bobcat tire on for about the fourth time the other day. A rock had rolled between the rim and the frame assisted by the tracks and crushed the rim pretty bad. I straightened it out, grinding, welding and polishing as needed. It kept coming undone. Whitlock watched as I was working and noted the rim spinning inside the bead of the tire about 100 miles an hour. ....Whitlock says I am exaggerating.........whatever..... I finally decided to run the pressure up to about 75 psi. Shortly all of the mounting soap was squished out and it grabbed the rim and hung on. Part of the problem was that I put 1/2 gallon of tire sealer inside with the little rubber chunks in it. It also was slippery until squished out of the bead area. Going good now.... ........until all of the violent digging rocks and clay jarred the battery mount loose, the bolt stuck under the alternator belt causing smoke to fill the cab and obstruct my vision..... the engine continued running destroying the belt and nearly jamming the bolt through the top of the battery.Whitlock says I always break things... well.... I have news for him. I didn't this time. For almost 5 1/2 hours.
Some of the wood we cut a while back is looking very much like barn or corral wood rather than the fine high quality stock I require for my precision craftsmanship.....
This year spring will make its earliest arrival since the late 19th century: 1896, to be exact. The vernal equinox — the first day of spring — will arrive Tuesday (March 20) at 05:14 Universal Time, or 1:14 a.m. EDT. Even more intriguing is that for those in the Mountain and Pacific Time zones, the equinox will actually arrive Monday night (March 19).
Ready for more spring here Windpower. Rick, we don't have enough work in California to be able to afford gas to get to Idaho, so possibly if you could just send the work this way and when you send the check we will send your roads back all repaired.....
