CountryPlans Design/Build Forum Building & Design help for the involved home owner
September 06, 2010, 08:24:42 AM *
Welcome, Guest. Please login or register.
Did you miss your activation email?
Login with username, password and session length
News: Welcome to the Small Home & Cabin Design/Build Forum!
• Feel free to ask & answer questions about building smaller homes, cottages, and cabins.
No Advertising - You may post a web link in your profile.
• Signup for free and start posting. Click REGISTER.
• Click PROFILE SETUP to update your membership data.
• Click SEARCH to find a topic quickly.
• Click HOME to return to the main CountryPlans.com website and our PLANS.
   Home   Help Search Login Register
Pages: 1 2 3 4 5 [6]   Go Down
  Print
Author Topic: letting in ledgers for floor joist.  (Read 25691 times)
Senior Member
Online Online
WWW
« Reply #100 on: June 03, 2010, 09:35:23 PM »
The codebook is referencing the NDS on notching restrictions. The NDS is assuming graded lumber. One thing I can think of is defect sizes vary with lumber dimensions. Assuming the driver of the ferrari knows to look for knots in the notch area then the 2x6 stud is stronger. If it's a dumb kid driving a ferrari at 100 mph I'd buckle up.
I'm not worried about the notch or ledger dimensions if they were being done as per the drawing in the codebook, a box on top of a box. That isn't what is being done here. Studs notched on their tension face are running 2-4' above floor level where rafters with ties in the upper third of the roof height are supported by them. That is where my concern level kicks in. I'd also be interested in an opinion on putting a 2x ledger on the outside compression face of the wall and then running sheathing over the notched area.
A traditional dutch barn is somewhat similar. They are built with H frame bents with rafters supported by the upright legs of the H. There have been 3 threads relating to failures in the past year on the TF Guild forum. The latest was a tour of multiple historic softwood barns. All had some degree of failure in that area.
Were the historic barns still standing?  If so, how old where they?
I have to wonder if another factor must be included:  The small house factor.  After all, a 14 foot whide 24 foot long house is going to have a great deal less weight then a 20 foot wide 40 foot long house under the same conditions.
Logged
Senior Member
Offline Offline
« Reply #101 on: June 04, 2010, 11:03:36 AM »
I give my engineer all the information I have that might be pertinent to help come up with the right solution. In that vein, a stud is intended to be axially loaded, look at the allowable slope of grain for a stud 1:4 and then for a #2, 1:8 , 3 times as steep as Select Struc at 1:12. I look at this situation more as a beam overhanging a post with a point load on the end, notched over the support on the tension face. Turn that diagram 90 degrees in your head and there is the kneewall with thrusting rafters except that we have a combined load.
Logged
Senior Member
Online Online
WWW
« Reply #102 on: June 12, 2010, 07:47:59 AM »
Sorry Don but you lost me...way over my head here.
I'm guessing you are saying that a 1 1/2" beam sitting on top of a 3 1/2" stud is different then a 1 1/2" beam sitting inside a 5 1/2" stud?
Logged
Senior Member
Offline Offline
« Reply #103 on: June 12, 2010, 01:35:49 PM »
That isn't what I said, my comments were for others.
It wouldn't hurt to read up on tributary area and loads while you wait, that should help with this;
Quote
Logged
Pages: 1 2 3 4 5 [6]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
