Author Topic: 16x36 in North Mississippi  (Read 33143 times)
Offline rick91351
  • 5000' in Idaho
Re: 16x36 in North Mississippi
« Reply #25 on: December 20, 2013, 06:26:32 AM »
 [cool]  That is a great idea
Offline jhivy
  • Junior Member
  • Welcome to the CP-Forum
« Reply #26 on: January 27, 2014, 05:27:16 AM »
Ready for metal.  If the wind ever stops blowing, I might get some put on.
Offline Tickhill
  • Look up ^
« Reply #27 on: January 27, 2014, 02:49:15 PM »
I recently changed jobs and I am in Meridian, man has it been windy today with snow/ice expected tomorrow. Glad to see you making progress.
"You will find the key to success under the alarm clock"  Ben Franklin
The slippery slope just got slicker
Offline jhivy
  • Junior Member
« Reply #28 on: February 03, 2014, 06:08:22 AM »
Half the roof is now covered in metal.
Offline jhivy
  • Junior Member
« Reply #29 on: February 24, 2014, 08:13:07 AM »
Roof complete.  Most of the sheathing complete.  Starting to look like a house.  Or a church, apparently, as most of my neighbors ask if it is.
Offline astidham
  • Skiatook Oklahoma
« Reply #30 on: February 24, 2014, 09:15:26 AM »
looks nice!
— Henry Ford
Offline jhivy
  • Junior Member
« Reply #31 on: March 17, 2014, 06:35:49 AM »
Wrapped.
Offline jhivy
  • Junior Member
« Reply #32 on: April 22, 2014, 05:23:59 AM »
Didn't realize it had been so long since I posted.  Windows in.  Laundry room dried in.
Offline jhivy
  • Junior Member
« Reply #33 on: July 02, 2014, 05:31:13 AM »
Windows trimmed.  Ready for siding.
Offline rick91351
  • 5000' in Idaho
« Reply #34 on: July 02, 2014, 06:49:57 AM »
Just a concern or question - Do your bedroom windows meet egress standards?  Or does it matter?
Offline jhivy
  • Junior Member
« Reply #35 on: July 02, 2014, 09:00:35 AM »
I will have no inspection, so it doesn't matter, but i don't want to trapped inside either.  Those windows are 28X60, so they'll be close.  I'd have to put a tape on the opening to find out for sure.  The perspective of the photo makes them look a little squattier than reality.
However, those are not the bedroom windows.  The bedrooms are actually in the loft.  Does a loft count as a bedroom?  Same requirements as an enclosed bedroom?  If so, my windows up there won't comply.  ???
Offline hpinson
« Reply #36 on: July 02, 2014, 02:17:37 PM »
Now you've opened a can of worms.  ::)
Offline MountainDon
    • My 15.75 x 30 Jemez Cabin
« Reply #37 on: July 02, 2014, 02:53:32 PM »
FWIW,
IRC section R310.1.1 Minimum opening area.
All emergency escape and rescue openings shall have a minimum net clear opening of 5.7 square feet (0.530 m2).
Exception: Grade floor openings shall have a minimum net clear opening of 5 square feet (0.465 m2).
Offline Don_P
« Reply #38 on: July 05, 2014, 04:41:48 PM »
Quote
Yes and yes. They would still like to have the possibility for you to self rescue or to get you out of that level if there is a fire below. Do try to work an egress in there. Small deck and a door?
Offline rick91351
  • 5000' in Idaho
« Reply #39 on: July 05, 2014, 09:14:28 PM »
I sort of thought one of the firefighters would way in here.  Part of the concern for 'egress' sizing is actually not egress but entering a burning building with an air pack.  Our old building inspector 'Builder Bob' was attempting to explain that to me a couple years ago.  I listened to his droning about entering a building with an air pack......  I rolled my eyes and said 'Bob this is Prairie we do not have a fire department nor even a fire district.  Nor will we ever have one up here.  No body is going to be entering a building with an air pack up here.'  Guess what we are now in the embryo stage of growing one!!!
Offline Patrick
  • Full Member
« Reply #40 on: July 06, 2014, 05:26:16 AM »
This is all Wisconsin says about lofts "(4) Exits from lofts.
SPS 321.03(4)(a)(a) At least one stairway exit shall be provided, to the floor below, for a loft exceeding 400 square feet in area.
SPS 321.03(4)(b) (b) At least one stairway or ladder exit shall be provided to the floor below for a loft, 400 square feet or less, in area. "
And egress "1. The nominal size of the net clear window opening shall be at least 20 inches by 24 inches irrespective of height or width. Nominal dimensions shall be determined by rounding up fractions of inches if they are ˝-inch or greater or rounding down fractions of inches if they are less than ˝-inch.
SPS 321.03(6)(b)2. 2. No portion of the window, including stops, stools, meeting rails and operator arms, shall infringe on the required opening. "
Offline jhivy
  • Junior Member
« Reply #41 on: July 07, 2014, 04:45:17 AM »
Corrugated siding going up.  I really like the look.
Offline jhivy
  • Junior Member
« Reply #42 on: September 19, 2014, 06:33:34 AM »
siding progress
Offline jhivy
  • Junior Member
« Reply #43 on: September 19, 2014, 06:35:17 AM »
Porch piers poured.
Offline dablack
  • Rusk TX
« Reply #44 on: September 25, 2014, 11:02:56 AM »
Looks good.  Did you have a truck come in to pour those or did you DIY?
Also, what did you decide to do with the roof insulation?
Offline jhivy
  • Junior Member
« Reply #45 on: October 01, 2014, 09:06:53 AM »
It was diy.  My dad has a mixer, so it was quick.  No hand mixing.
I will go with spray foam in the rafters.  I used a "cool roof" design where the metal sits above the decking on a grid of laths.   The idea is that separating the roof material from the decking and using a highly reflective roof will reduce heat transfer.  That and it made it much easier to put the metal on a 12/12 pitch.
Offline jhivy
  • Junior Member
« Reply #46 on: October 27, 2014, 05:50:00 AM »
Love the look of the exposed rafter tails.  Didn't love the painting part.  But its done now.
Offline jhivy
  • Junior Member
« Reply #47 on: November 24, 2014, 05:47:28 AM »
Utility room covered with Hardie Panel.  Just needs some battens and paint.
Offline jhivy
  • Junior Member
« Reply #48 on: December 01, 2014, 06:18:31 AM »
Painted.  The color matches well.
Offline jhivy
  • Junior Member
« Reply #49 on: December 01, 2014, 06:32:33 AM »
