16x36 in North Mississippi
Started by jhivy, October 03, 2013, 09:26:43 AM
jhivy
Ready for metal.  If the wind ever stops blowing, I might get some put on.
Tickhill
I recently changed jobs and I am in Meridian, man has it been windy today with snow/ice expected tomorrow. Glad to see you making progress.
jhivy
Half the roof is now covered in metal.
jhivy
Roof complete.  Most of the sheathing complete.  Starting to look like a house.  Or a church, apparently, as most of my neighbors ask if it is.
astidham
— Henry Ford
jhivy
jhivy
Didn't realize it had been so long since I posted.  Windows in.  Laundry room dried in.
jhivy
Windows trimmed.  Ready for siding.
Just a concern or question - Do your bedroom windows meet egress standards?  Or does it matter?
jhivy
I will have no inspection, so it doesn't matter, but i don't want to trapped inside either.  Those windows are 28X60, so they'll be close.  I'd have to put a tape on the opening to find out for sure.  The perspective of the photo makes them look a little squattier than reality.
However, those are not the bedroom windows.  The bedrooms are actually in the loft.  Does a loft count as a bedroom?  Same requirements as an enclosed bedroom?  If so, my windows up there won't comply.  ???
hpinson
Now you've opened a can of worms.  ::)
FWIW,
IRC section R310.1.1 Minimum opening area.
All emergency escape and rescue openings shall have a minimum net clear opening of 5.7 square feet (0.530 m2).
Exception: Grade floor openings shall have a minimum net clear opening of 5 square feet (0.465 m2).
QuoteDoes a loft count as a bedroom?  Same requirements as an enclosed bedroom?
Yes and yes. They would still like to have the possibility for you to self rescue or to get you out of that level if there is a fire below. Do try to work an egress in there. Small deck and a door?
I sort of thought one of the firefighters would way in here.  Part of the concern for 'egress' sizing is actually not egress but entering a burning building with an air pack.  Our old building inspector 'Builder Bob' was attempting to explain that to me a couple years ago.  I listened to his droning about entering a building with an air pack......  I rolled my eyes and said 'Bob this is Prairie we do not have a fire department nor even a fire district.  Nor will we ever have one up here.  No body is going to be entering a building with an air pack up here.'  Guess what we are now in the embryo stage of growing one!!!
Patrick
This is all Wisconsin says about lofts "(4) Exits from lofts.
SPS 321.03(4)(a)(a) At least one stairway exit shall be provided, to the floor below, for a loft exceeding 400 square feet in area.
SPS 321.03(4)(b) (b) At least one stairway or ladder exit shall be provided to the floor below for a loft, 400 square feet or less, in area. "
And egress "1. The nominal size of the net clear window opening shall be at least 20 inches by 24 inches irrespective of height or width. Nominal dimensions shall be determined by rounding up fractions of inches if they are ½-inch or greater or rounding down fractions of inches if they are less than ½-inch.
SPS 321.03(6)(b)2. 2. No portion of the window, including stops, stools, meeting rails and operator arms, shall infringe on the required opening. "
jhivy
Corrugated siding going up.  I really like the look.
jhivy
jhivy
dablack
Looks good.  Did you have a truck come in to pour those or did you DIY?
Also, what did you decide to do with the roof insulation?
jhivy
It was diy.  My dad has a mixer, so it was quick.  No hand mixing.
I will go with spray foam in the rafters.  I used a "cool roof" design where the metal sits above the decking on a grid of laths.   The idea is that separating the roof material from the decking and using a highly reflective roof will reduce heat transfer.  That and it made it much easier to put the metal on a 12/12 pitch.
jhivy
Love the look of the exposed rafter tails.  Didn't love the painting part.  But its done now.
jhivy
Utility room covered with Hardie Panel.  Just needs some battens and paint.
jhivy
Painted.  The color matches well.
jhivy
